Sponsored by: Real Truck
Tires Rubbing Left Spring?
Old Oct 29, 2007 | 10:17 PM
03F250's Avatar
03F250
I just bought a used f250 4x4, and it came with bf goodrich 265/70 all terains. The tires are rubbing the leaf springs in the front when the wheel is all the way turned. Is this a normal problem or should i get something checked out?
Old Oct 29, 2007 | 10:54 PM
UP_There's Avatar
UP_There
mine rubs the right spring at FULL turn if I crank to the right......rims are correct offset.....just a Ford thing! Seems odd that yours would rub with 265/70's! I am running 315/75/16's. Mine didn't rub at all running 305/70/16's
Old Oct 30, 2007 | 10:49 AM
Beerstalker's Avatar
Beerstalker
That doesn't seem right. Take a picture of the wheels and tire, I have a feeling someone put either aftermarket or 05-up rims on your truck which have the wrong offset.
Old Oct 30, 2007 | 11:03 AM
bigrey6306's Avatar
bigrey6306
yeah, sounds like the wrong rims...
I had aftermarket rims 4.5 BS i think with a 4 in lift and 35 in tires... no rubbing
now have a 8 in lift with same rims and 37 in tires... get slight rubing on front left leaf spring, but the tires are Swampers and the big lugs rub, once they get a lil more worn, I am thinking it will stop...
Old Oct 30, 2007 | 11:04 AM
PowerStrokeHD's Avatar
PowerStrokeHD
I have a feeling that your right, considering he said he has 265/70's.
265/70R17 would have been the factory size for '05-up. Factory on his '03 would have been 265/75R16.
892504x4
Offroad & 4x4
Dec 13, 2022 01:10 PM
xmontex4
Sep 7, 2012 08:48 PM
douglasandy
Jan 1, 2011 05:43 PM
Powerstroke-7.3
Dec 7, 2010 05:08 AM
hawaiiv6
Oct 3, 2007 07:50 PM
