Sponsored by: Real Truck
2000 7.3L Turn signal fuse keeps blowing
Old Oct 29, 2007 | 10:17 AM
planders_99's Avatar
planders_99
I have a sweet 2000 Crewcab 7.3L Diesel. Two days ago, I noticed the turn signals weren't working and found the 20 amp fuse (#1 position) was blown. Replaced the fuse and the lights worked again for a short time. Have gone through two more fuses. Obviously, the fuse is not the problem. Any ideas? Also, where is the flasher located?
thanks,
Pete
Old Oct 29, 2007 | 12:20 PM
Baja Daze's Avatar
Baja Daze
My '02 did the same thing, started about a week after I bought it. Took the techs almost a week to find and fix the problem. After they traced all the wiring, they found that one of the connections were bare and when hitting bumps while signaling, the bare wire would contact the body and make a ground, shorting out the system. I'd suspect that it's simply a loose or bare wire somewhere - good luck finding it.
Old Oct 29, 2007 | 12:26 PM
Jim59's Avatar
Jim59
I had a similar problem ..... there was a short in the fuse box .... had to replace it.
Old Oct 29, 2007 | 08:25 PM
high ho silver's Avatar
high ho silver
thanks,
Pete
The #1 fuse in the cab or under the hood? Are you towing anything? If you are, a bad trailer ground will sometimes blow light fuses because the only ground it can get is thru the ball and bouncing around causes them to blow.
tztony
Dec 27, 2016 03:30 PM
mrc00l88
Dec 11, 2016 07:33 PM
Ronnie Gilliam
Aug 25, 2014 02:12 PM
sstipiotis
Oct 22, 2007 12:58 PM
planders_99
May 16, 2006 11:13 AM
