Replacing fluid/gasket in rear "pumpkin" 97 5.0
How hard/easy is it to replace the gasket and the oil in the rear pumpkin? It has a leak and I don't know how long its been that way but I just discovered it the other day. The bottom half is covered in oil, I'm assuming its leaking somewhere. Its pretty rusty too. Looks like 10 bolts and the cover is off. Easy enough?
Thanks....
1997 5.0 AWD XLT
Thanks....
1997 5.0 AWD XLT
Wipe the bottom of the carrier out with paper towels, and check for any debris or metal shavings.
Ford recommends synthetic 75W-140 for the rear diffs.
There's also a possibility the leak is coming from the pinion seal, but that'll be obvious when looking at the diff from the front.
Good luck.
how best to check the level? also, if I am just topping off, can I just add some of the 75w synth oil to whatever is in there?
Thanks
To check the level there is a plug on the left side of the housing. It is much easier to access if you remove the left tire.
I was under there today (took bear's advice, and switched to 5w30 for the winter coming, and the long trip ahead)
While I was draining the oil, I felt/saw the plug for the front diff it's at the top left (correct?) I just stuck my 3/8 ratchet in there, and it did loosen... didn't seem to be attached to anything, so I assume that was the fill plug... of course, I could not see it at all - just did it by feel, but it it's the same design as all the other diffs I have ever seen by ford, that should be the fill plug, correct? or are they more than one?
you are exactly right - the 3rd member is RIGHT there... maybe 2 inches between... DARN!!
actually, I could siphon out the old oil, and then just refill with new... it may not be as good as pulling the plate, but I can't really remove that 3rd member easily, and it's not dripping enough for me to worry about it, esp if I only have to top it off once in a while... that can't be easy to do for a weekend hack like me :-)
I just don't want to run the thing out of oil there, and burn up the front end... I assume that it is always "working" even if 4x4 is not being used?
Thanks
so, should I use 75w90 gear oil? which brand is best?
Front Differential - only has a fill plug. I doubt you can siphon the oil out, too thick for that. You can pump it out though which is what I do. Not as thorough as removing the plate but a whole lot simpler and you can get most of the oil out if you get a hose in there properly. Oil type depends on vehicle but Ford recommends synthetic 75W-140 for most 95-01 year models. Check specs in owner manual.
Was it offered as an option you could buy? or did ford only make one rear end for that year/make/model?
yeah, I have a hand pump that I use for stuff like this - I think it would work great in this case....
I'll get a decent 75w 90 for the front end, and 75w 140 for the rear...
