Some fan speeds in truck dont work???
It's gotta be the resistor I'd say.
Usually only one speed goes at a time though, but I'm betting its the resistor.
Each coil (three different gauges) in the resistor provides different amounts of 'resistance' based on the fan speed you select. High usually always works since no resistance is provide and the fan can run at max. (it's bad for the blower to always run on high)
I have issues with mice out here and they've trashed two of mine giving the same issues you describe. Someday I'm gonna screen off all inputs/outputs to the blower. (Irish spring soap and moth ***** don't deter mice by the way)
Hmmm, worked for two weeks eh? Were you very careful with the new one when you installed it? Has 'something' gotten in there and put debris in the coils making them short out (again)? The coils are quite fragile and can't take too much banging around. It wouldn't take much to short those coils out either. Don't remove the tabs that lay across the top of each coil either.
Since it worked for two weeks, I think you're having resistor issues.
In case you haven't already, veryify the condition of all your wires leading to the resistor and from the resistor to the blower. Who knows, maybe something is shorting it out
Good luck bro
Good luck bro
Originally Posted by NeXtras
can some one show a picture of what the resistor is and where to find it under the hood? Thanks
Here is a link to the location.
http://i54.photobucket.com/albums/g9...orResistor.gif
Here is a photo of one.
is it normal for all the speeds to go at once? do all speeds have there own coil or resistor?
Here is a link to a diagram.
http://i54.photobucket.com/albums/g9...lowermotor.gif
