Bucking Problem on 2002 Ranger Tremor
Old Aug 29, 2007 | 08:11 PM
Tremor23's Avatar
Tremor23
I have a 2002 Ranger and I seem to have a problem when my truck is going up hill. It starts bucking as if it is in to high a gear and going to slow or as if it is having a problem with fuel. I have changed the fuel filter and run injector cleaner in almost every tank full of gas. It also does the same bucking when I first start the truck for the day and if my A/C is running. Has anyone every experienced anything like this or am I just losing my mind?? Any help would be greatly appreciated.
Chris
Old Aug 29, 2007 | 11:09 PM
big 390's Avatar
big 390
mine does it when the a/c is on and im sitting at a stop in drive. i can feel the hole truck move.
Old Aug 30, 2007 | 03:37 AM
03 Maz B23's Avatar
03 Maz B23
Might try cleaning your MAF sensor. If you have alot of miles on the spark plugs you could try replacing them as well.
Old Aug 30, 2007 | 05:28 AM
markfh11q's Avatar
markfh11q
I'm having the same problems right now and it turned out to be a bad canister purge valve. Do you have any trouble codes coming on?
You could:
Check fuel pressure.
Check for trouble codes.
Act accordingly.
You did the right thing changing the fuel filter though. Although it doesn't work sometimes, (like now), it does things like this a lot. We had one clog up on our tractor the other day...
I would try cleaning the MAF sensor too. I did that a while ago when my truck was idling rough, (turned out I just forgot to plug the PCV valve back in after removing the upper intake... ). Anyways, when I DID reconnect the valve, it ran smoother anyway.
You could also change the plugs and wires if you haven't done so recently. My 96 still had the original wires, (and probably the original plugs), on it, and it was starting to miss at higher speeds. Each gap was corroded to about .8!
Old Aug 30, 2007 | 08:17 AM
pawpaw's Avatar
pawpaw
Does it do this buckng with the A/C off????
If so, check your plug gap as has been suggested.
Old Sep 3, 2007 | 08:49 AM
Tremor23's Avatar
Tremor23
Thanks for all the info. I will check a few things out. The plugs are new, gapped correctly, wires are new, fuel filter is new, and I have had no trouble codes at all come on. Anyway, I will see what I can find. I am in the process of taking to ford for a recall so I might get them to check out my truck for me. Thanks again, Chris.
Old Sep 3, 2007 | 11:15 AM
Rockledge's Avatar
Rockledge
Then have a FULL fuel pressure check done while you are at it (meaning, have them also check the FP while the engine is under load).
Tremor23
Feb 5, 2008 12:18 AM
Tremor23
Jan 12, 2008 05:18 PM
freirefishing
28
Apr 27, 2007 01:58 PM
fordlvr25
Oct 8, 2004 08:13 AM
Eliot
May 17, 2004 08:41 PM
