Sponsored by: Auxito
Major slop in 98' f150 rearend.
Old May 9, 2007 | 11:56 AM
Merculous's Avatar
Merculous
My rearend in my truck clunks like crazy when you take off from a dead stop. I thought it was a u-joint but found there is some major play in the diff. If I grab the pinion flange, I can rock the pinion side to side like 2 inches. This is with the wheels on the ground and blocked so they can't move. All the slop is in the diff.
-How could this start all of a sudden?
-Could the crush sleave on the pinion have colapsed and caused major tooth clearance at the ring?
-How could this have that much play? I'm scared to remove the diff cover!
Any sugestions?
Old May 9, 2007 | 02:07 PM
Silver Streak's Avatar
Silver Streak
If you remove the cover you'll probably find an issue with either the spider gears or the cross shaft. When I rebuilt my 8.8 there was a ton of slop in it and that is where I found it, but mine had about 250k miles on it at the time.
a.s.k.52
Jul 21, 2013 07:59 AM
Matt8393
1978 - 1996 Big Bronco
Oct 9, 2010 08:20 PM
i-w
Oct 12, 2009 04:08 PM
brett_d
Jun 21, 2002 07:18 PM
