1978 - 1996 Big Bronco
Plug wires for 95 5.0 Bronco
Old Apr 28, 2007 | 07:54 PM
biederboat's Avatar
biederboat
Are there any "as good or better than factory" plug wires that are absolutely the same fit (length)? I need to replace mine and when I did my last Bronco, the "OEM style" was still different in length, some were longer.
Thanks,
Biederboat
Old Apr 29, 2007 | 12:05 PM
lostin90s's Avatar
lostin90s
Well the mega parts ones don't fit exactly. Around hereon FTE it seem most go with the 9mm Ford racing wires . I Had a set on 3 different trucks they hold up great and if you use a MDS 8227 coil and a 94 95 Mustage dizzy cap it can liven up ride a little. I use Ford wires or go with the better high proformance wire In the long run you will get better service out of them. Good luck
Old Apr 29, 2007 | 12:43 PM
biederboat's Avatar
biederboat
Thanks, I just started checking around a bit and that seems to be the concensus. I think my entire ignition system is not only ready for replacement but an upgrade as well.
Biederboat
Old Apr 29, 2007 | 05:19 PM
helirich's Avatar
helirich
I had bad experince with Ford Racing Wires. (burnt off) I do have headers. I got excell 8.8 hitemps and they work great.
Old May 1, 2007 | 12:46 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
Thanks,
Biederboat
We offer our Live Wires with off-the-shelf part numbers OR you can order them from us and have us build each wire to the exact length you want for each cylinder. Also with the specified boot angles.
http://www.performancedistributors.com/livewire.htm
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
