dead on the water
Old Mar 21, 2007 | 04:59 PM
93blueoval f-250's Avatar
93blueoval f-250
dead on the water
have an 88 e150 w a 5.0.it is getting fuel up to the injectors but there is nothing getting to the motor.what tells the injectors to fire? could low fuel pressure be a problem ?what is it suppose to be?what is a tfi module?thanks in advance
Old Mar 21, 2007 | 10:13 PM
LxMan1's Avatar
LxMan1
The TFI module fires the ignition and injector drivers in the ecm. It is the module on the side of the distributor. You should have 32 to 40psi at the fuel rail.
Old Mar 22, 2007 | 03:44 PM
93blueoval f-250
now i changed the tfi module with no results.how can u tell if the ecm is bad?is this something i could do myself?the numbers on ecm r gone ?anyway to tell what it is?
Old Mar 23, 2007 | 12:09 AM
LxMan1's Avatar
LxMan1
Check the EEC relay. It could be bad.
Old Mar 23, 2007 | 08:59 AM
93blueoval f-250
where is it located?
Old Mar 23, 2007 | 09:29 PM
LxMan1's Avatar
LxMan1
Not sure on a van, it's usually under the hood, and near the fuel pump relay. Sometimes there is a marked cover over them.
Old Mar 24, 2007 | 08:17 AM
93blueoval f-250
that was it i changed the relay and she fired up.now the fuel pumps wont shut off
Old Mar 24, 2007 | 06:55 PM
LxMan1's Avatar
LxMan1
Perhaps the fuel pump relay is stuck on?
jlo84truck
Jul 27, 2014 12:51 PM
VONxRUBENxLA
Modular V10 (6.8l)
13
Aug 15, 2012 03:29 PM
kenlippold
Mar 6, 2011 04:29 PM
93f250idi
Dec 4, 2010 01:53 PM
Curtis234
1978 - 1996 Big Bronco
Oct 26, 2006 10:11 AM
