hub vacuum lines
Old 03-14-2007, 10:03 PM
RedDragon's Avatar
RedDragon
RedDragon is offline
hub vacuum lines
I just replaced my ball joints. When I put everything back together, one of the vacuum lines would not go back into the knuckle/hub. It is a fine thread and looks like it could possibly be stripped, but I'm not 100% sure. I didn't want to try to force it too hard and mess up the threads even more. Does anyone know what the thead size is? Is it possibly NPT and I just didn't get enough force to get it in there? The passenger side when back on easy. What problems will leaving it off for a day or two create, other than a little dust in the hub? Any suggestions to get it back on? Thanks
Old 03-14-2007, 10:27 PM
mech2161's Avatar
mech2161
mech2161 is offline
I've used 1/8 npt fittings on some that have been broken.
Old 03-14-2007, 11:32 PM
rollerstud98's Avatar
rollerstud98
rollerstud98 is offline
i'm about to do my ball joints, so i'm wondering the wheel bearings, are they easy to get at cause i figure i might aswell grease them up while i've got everything apart
Old 03-14-2007, 11:46 PM
mech2161's Avatar
mech2161
mech2161 is offline
The wheel bearings are a sealed unit. The inner seal is attached to the axle and will need to be replaced when removed. If you've not done this before you better do some research.
Old 03-15-2007, 12:01 AM
rollerstud98
my dad is a licenced mechanic but is no longer in the business, this is the one thing he wanted me to find out, thanks
Old 03-15-2007, 12:55 AM
RedDragon's Avatar
RedDragon
It wasn't too hard to replace joints. The axle seal took a little care to get on straight. I think I got it on without any damage.
Old 03-15-2007, 01:52 PM
rollerstud98
what did you use to put it one? i picked up a couple seals cause i wasn't exactly sure which one i needed, but i can return whatever i don't use so its all good
Old 03-16-2007, 12:18 AM
RedDragon's Avatar
RedDragon
I used a 10" long piece of 1-1/4 inch pipe with floor flange & cap on the ends. Slide on the seal, slide pipe & flange over axle, and carefully hammer the pipe until the seal seats.
