newbie-what do your stock temp gauges read
I just bought a 250 diesel and the stock temp gauge seems to read very low. Its about an 1/8 inch above the coolest running temp reading. All my gassers normally run about 1/2 way to red (right in the middle of the gauge). its not too cold here, about 0- 10C, and the gauge is always in the same spot. Is this normal running temp or do I need a new thermostat?
Probably a bad temp sending unit if it never shows it warming up. Does the engine seem to be a "normal" temp after it's been running a while? If it seems cool, it's a stuck open thermostat. When I bought my truck, it was doing the same thing. The dealership replaced both the sending unit and the thermostat. Now it runs in the middle of the range after warmup.
Joe
Joe
mine starts at the bottom when cold moves up to that spot and stops. I did have it move before when my radiator was full of mud. It was at the normal spot for awhile then i had to do a high speed sprint down the freeway at 90 and i looked down and it was up towards the top of the normal operating range. After i cleaned out the radiator, it has never went there again.
Originally Posted by largefries
No it doesn't move at all, and yes it is in the lower 1/4" of the normal range. I guess that's normal, I just thought it was a little strange. Well, happy to hear I don't need to do anything, it worried me a bit.
It starts at the bottom, from starting the engine cold the gauge reads cold. Then it moves up to the operating temp (1/4" in to normal), then stays there. So it sounds like it's fine.
The factory gauge isn't much more than an idiot light in my opinion. I have installed an autometer gauge that is much better at showing temp changes.
If you only have the factory gauge, I recommend driving the truck for 10 - 15 mins before getting greedy with the throttle. That usually gets my truck up into the 160 or so range depending on the ambient conditions.
