Swap the 3.0 Vulcan for the 3.0 Yamaha?
Old Mar 8, 2007 | 12:33 AM
Benaghetto's Avatar
Benaghetto
What are the possibilities of putting the Yamaha 3.0 V-6 in place of my Vulcan? I know the engines seem to be vastly different, but from what I understand they are closely related. I know they have the same computer for a fact as they are from the same generation of cars. Maybe Rockledge can shed some light on this since I noticed his sig includes a 94 SHO.
Old Mar 8, 2007 | 07:33 AM
wendell borror's Avatar
wendell borror
I just read the other day that ford supplyed the block to yamaha and they used the duratec block.
Old Mar 8, 2007 | 08:39 AM
BSmitty's Avatar
BSmitty
AFAIK, and take this with a grain of salt, the Vulcan and the Yamaha have the same bellhousing. I've heard that the SHO 3.0l swap is best done on a 3.0l equipped truck for that reason, but of course I've never confirmed this. It would be an interesting swap, that Yamaha 3.0l was a great engine.
Old Mar 8, 2007 | 09:40 AM
rubydist's Avatar
rubydist
Its been done once or twice, but its a lot of work. The SHO motor takes an Aerostar bellhousing, as I recall, to work in the Ranger. (Not sure if that's the same as the 3.0 Vulcan or not...) The SHO motor is very wide, so its a challenge from that standpoint. It also likes to rev - its not huge on torque, but it will run 8k rpm, so it needs to be geared a lot different from a regular Ranger motor.
The SHO motor is a thing of beauty, but parts are expensive, so make sure your wallet is healthy if you decide to tackle this one. I'm about to do the 100k maintanence on my SHO, and a new waterpump was $125.00 ($250.00 from Ford...) and some of the parts are starting to be really hard to get.
Old Mar 8, 2007 | 03:59 PM
Benaghetto's Avatar
Benaghetto
I'm semi familiar with the SHO's. An ex-general manager of mine was a SHO fanatic, and knows every inch of them. Sure it'd take some rearanging to widen the engine bay enough to be comfy puting the motor in, but I cant say that its completely unreasonable. Just last week he picked up a 93 SHO manual with the 3.0 for $500 that "wasnt running". After replacig a part or two he had a running engine! Its going to be his project car for a centrifical charger system he's going to buy from shoshop.com My point is that he could probably come across another down the road and wonder if there's any MAJOR hangup that'd prevent such a swap.
Old Mar 8, 2007 | 04:09 PM
BuffmanLT1's Avatar
BuffmanLT1
Hey I wouldn't mind swapping an SHO motor in my ranger. I don't need half the crap under my hood so I can clearance all I need But alas too much $$$ for a winter car.
Old Mar 8, 2007 | 05:27 PM
Rockledge's Avatar
Rockledge
The 3.0L/3.2L SHO engine is all Yamaha. Ford initially was going to supply the block but Yamaha said no thanks we'd rather build our own. The 3.0L/3.2L Yamaha block and the Vulcan block do have the same dimensions, though.
Regarding the SHO engine in a Ranger:
http://rockledge.home.comcast.net/Ra.../SHORanger.pdf
https://www.ford-trucks.com/forums/s...37&postcount=4
Old Mar 8, 2007 | 07:05 PM
RangerPilot's Avatar
RangerPilot
Ok enlighten me, I'm not too familiar with SHO engines at all.
Rockledge said the 3.0L/3.2L SHO is all Yamaha, then the 3.0L/3.2L Yamaha block shares the same dimensions with the Vulcan block.
But in a previous post it was said it's much wider and hard to fit into the Ranger without modification.
So what's the difference? Is it wider, and if so how much? I'm assuming the 8K revving SHO is OHC...I can't imagine revving any OHV engine to 8K.
Old Mar 8, 2007 | 08:08 PM
Rockledge's Avatar
Rockledge
The Yamaha is a DOHC engine. The difference in width/size can mostly be attributed to the heads and cams.
Here's a shot of a Vulcan head and a Yamaha head:
Old Mar 8, 2007 | 08:48 PM
rubydist's Avatar
rubydist
Here are a couple of other photos that help give you an idea of how wide the engine is:
Those big valves angle outward, and have big covers over them, and (since its dohc) its got 2 camshafts on each head. Its got dual intake runners with butterflys on the highspeed runners that open at around 4400 rpm. It has a torque curve that's almost flat to the redline, so its a blast to drive!
IIRC, its as wide as the 4.6 modular motor.
Old Mar 8, 2007 | 10:10 PM
RangerPilot
Ah I see...DOHC and four valves a cylinder...quite nice indeed.
Ok...HP and torque specs please? Looks like a monster engine in a small displacement. Tell you what though, lookin' at rubydist's second picture I think working on it would be a total PITA.
Old Mar 8, 2007 | 10:54 PM
fflintstone's Avatar
fflintstone
Yeah, engine out just to do plugs. That head design has always been a killer, especially with 4 valves per. Formula one race cars have amazingly small displacement but the have enormous #'s. DOHC eliminates rocker arms and behave themselves better at high revs.
Old Mar 8, 2007 | 11:31 PM
Rockledge's Avatar
Rockledge
No, not on the Yamahammer 3.0L/3.2L. The spark plugs can be changed out by removing the "snakes" (upper intake) and using a few extensions and swivels on your ratchet.
Formula one race cars have amazingly small displacement but they have enormous #'s. DOHC eliminates rocker arms and behave themselves better at high revs.
Yep, and as noted the Yamaha 3.0L/3.2L is a high reving machine (8K+) and so it falls into a similar category. In fact, the only reason the SHO engine (as installed in the Taurus) isn't allowed to rev over 8K is because components such as alternators and PS pumps can't handle the higher RPMs.
Old Mar 8, 2007 | 11:58 PM
BuffmanLT1's Avatar
BuffmanLT1
any OHV engine can rev to 8k and beyond when properly setup and is meant to revv that high.
Old Mar 9, 2007 | 07:21 AM
wendell borror
Wouldn't it make more sense to swap in a 4.0 sohc as it's made for a ranger, has better lowend torque and simlar hp numbers? It may not rev to 8000, but it doesn't need to. The yamaha v8 got a bad rap for not being as fast as the v6, but I bet if they would have but a manual tranny behind the v8, it may have been a different story.
