What year motor in my 66 F100
Old Feb 10, 2007 | 08:08 PM
tomrooster-1's Avatar
tomrooster-1
I found a D5 PART # on the intake manifold and a D3 on the left cyl. head and a D2 on the lower block passenger side in front of motor mount. FE motor. Thanks, Tom
Old Feb 10, 2007 | 09:00 PM
seetwisted's Avatar
seetwisted
D is 70's...75,73,72...sounds like it's seen a little work at some time or another. I bought a motor for parts once that had a mixed bag of 70's numbers on the parts. When I tore it down, all the insides were mismatched also. Different years on the rods, crank and the pistons were from about three sets,including one piston from a 428 in a 390... I hope yours is not like mine. It eventually took 3 motors to get enough parts for one good one.
Old Feb 10, 2007 | 10:42 PM
airharley's Avatar
airharley
A little good news is that you can have different casting codes on one engine. Hopefully your heads have the same codes. Since you intake manifold has the later year code for 65 chances that it still is be a stock engine. Some year castings will carry over for a decade without much change. The 460 engine is a good example. The D1VE block was same until the D9VE came out. So don't get too caught up in the # game until you find out for sure.
If you give us all the full casting #'s we'll be able to tell you what is what.
Old Feb 11, 2007 | 03:25 AM
tbm3fan's Avatar
tbm3fan
Now wouldn't the D5 prefix for the intake manifold indicate a 1975 year and not a 1965? If that FE manifold has that little dog leg at the carb mount then that would cinch it as the 60's didn't. That would make more sense with all the D part numbers present which means he has a replacement engine and it is probably the more common 360.
Old Feb 11, 2007 | 03:33 AM
airharley's Avatar
airharley
Oh how I hate typing errors. Thanks for the catch Mike. That is the reason I was asking for the full casting code so we knew what he has verse guessing.
Old Feb 11, 2007 | 06:09 AM
banjopicker66's Avatar
banjopicker66
You can check the stroke easily enough, and that will tell you if it is a 360 or a 390.
Unless someone really wanted an upgraded 352 rebuild with '70s parts, it will be either a 360 or a 390.
Old Feb 12, 2007 | 07:12 PM
tomrooster-1
The manifold part# is D5TE9425KB
The block # is DT3E
the head # is D2TE AA or D2TE A4
I didn't check the stroke yet but I will
Tom
2009 - 2014 F150
May 28, 2014 02:27 AM
tomrooster-1
May 23, 2014 07:02 PM
Tom D
Bio-diesel, Propane & Alternative Diesel Engine Fuels
15
Mar 25, 2008 07:29 AM
Placermike
Nevada Chapter
Jul 12, 2007 10:29 PM
