Cab corners for 46?
Old Jul 16, 2001 | 12:22 AM
dmacklewis's Avatar
dmacklewis
Cab corners for 46?
Does anyone know of a source for cab corner patch panels for a 40-47 1/2 ton? Mine are going and I'm not handy with an English wheel or I'd fabricate my own.
dml
Old Jul 20, 2001 | 02:02 PM
Carlene's Avatar
Carlene
Admom
Cab corners for 46?
DML - didn't want to leave you out here hanging for too long. I've been looking through all the books & magazines we have at home and have been unable to find anything. Someone said you can get them through Bob Drake, but all I found there was for newer models. (50's & up)
Luckily we only have very small rust holes on the floor board inside the cab where the carpet laid and the lower part of the doors. The cab's perfect with the exception of a small dent on the roof.
You may want to try what we did with the lower door parts.
Steve CAREFULLY pryed and cut the lower part of the outer door skin off and took it to the local metal shop. They formed and bent the new ones and only charged us $25 for the pair.
Old Jul 25, 2001 | 12:33 PM
fatforty's Avatar
fatforty
Cab corners for 46?
Hi, I'm still looking for cab corners for my 40 but every catalog I look in is all from 50 up I really don't know where to send you for any info I think I will end up making my own. John
Old Jul 31, 2001 | 07:15 AM
Spoelstra's Avatar
Spoelstra
Cab corners for 46?
Old Dec 25, 2004 | 07:35 PM
loholland's Avatar
loholland
Patch Panels for 46
Northern Classic trucks has patch panels, also complete beds and floor boards.
Log on their web site and ask for a catalog.
Old Dec 26, 2004 | 05:45 PM
biglee's Avatar
biglee
Hi DML,
You can also get the left or right cab corners at; Wolf Steel Restorations,Steel Body Panels. The site is;http://www.alfaparts.net/ford42.htm.
They sell for $70.00 each.
They cover 1940-1947 pickups.
Hope this helps.
Lee
Old Jan 2, 2005 | 09:22 PM
TrekChick's Avatar
TrekChick
Hi, this is Jim - (TrekChick is my WIFE). I couldn't find any patch panels for my '47, so I fabricated them from a metal bucket. The lip on the bottom is close, and it's rounded, so it with a little bending and fabrication, it fit perfectly, and I just welded it right in. Check out my website: www.coolworktrucks.com
~~~Jim
Old Jan 6, 2005 | 10:42 PM
3Mike6's Avatar
3Mike6
~~~Jim
That's what I call improvising!!
I have a '31 Dodge PU and nonone make corners for it, mine were rotted out.
I sat around trying to figure out what to do, one day stumbled across a '78-81 Camaro front fender. Got to eyeballing it, and sure enough the front portion was a darn near exact match for what I needed.
Even if patch panels are available, why spend the hundreds of dollars when a little ingenuity can prevail...??_
Old Jan 7, 2005 | 06:42 PM
5 Star's Avatar
5 Star
40-47 Patch Panels
[B]Norther Classic Trucks, has all that you need for your truck in sheet metal, floors beds etc.
Theis web site is www.northernclassictrucks.com
Old Jan 29, 2005 | 01:59 AM
51ford fan's Avatar
51ford fan
Depending on how bad the rust is, I would just repair what is needed. Most of the replacement panels are designed to replace the entire section. My 51 only had a couple flat sections rusted out the size of a quarter in each rear corner. I used an air powered die grinder with a wafer thin cutoff wheel and just cut out the bad spots. Then welded in 18ga sheet metal with a Mig welder.
Old Jan 29, 2005 | 11:44 AM
Dodge41's Avatar
Dodge41
Just an Idea here, but why dont we make a sticky about repair panels. Lets face it, all 42-47 love to rust away, and a mint one is well, Ive never seen one without rust! So Wouldnt a sticky about repair panels by years and then suppliers or something work out great?
4x41977
Nov 15, 2012 08:44 PM
ANTIDodge
Paint & Bodywork
Apr 1, 2008 06:41 AM
reamer
19
Dec 12, 2005 02:06 PM
78bigunns
Oct 14, 2001 11:45 AM
StockMan
Sep 27, 2001 07:43 PM
