Gas Tank Dents
Old Jan 14, 2007 | 09:16 PM
mamelukesword's Avatar
mamelukesword
Gas Tank Dents
I have a van gas tank that I would like to install under the bed of my 52. Is there any way to pop out dents in a tank????? What can I say I am cheap.
Old Jan 14, 2007 | 11:55 PM
CharlieLed's Avatar
CharlieLed
Many different ways...with the rise in popularity (and the availability of trained technicians) I would talk to one of the paintless dent repair folks in your area, they are trained to come in through a limited opening and push out dents and dings.
Old Jan 15, 2007 | 07:44 AM
AXracer's Avatar
AXracer
Dents? was the tank mistreated after removal, or are these from road contact/collision? If the latter, be sure any abrasion hasn't weakened the metal to the point there is a weaping leak. Gasoline has a much lower surface tension than water or other such liquids so will seap thru the finest of holes. After having the tank straightened I would recommend cleaning the inside and slush coating it to be sure it is fully sealed. Of course by the time you do all that, it might be cheaper (and safer) to find another tank in pristine shape.
Old Jan 15, 2007 | 08:07 AM
mechmagcn's Avatar
mechmagcn
I once worked a summer job at a place that made 55 gal. drums and reconditioned used drums. On the ones that were dented, they would use around 2-3 psi of air pressure to straighten dents. On a gas tank I would make sure no gasoline was still present before pressurizing it though (and maybe fill it with water)
Old Jan 15, 2007 | 09:44 AM
arctic y block's Avatar
arctic y block
I used air on a drum several times. And I will state as fact that 7 psi will blow it up. Use on gas tank with caution.
Now this may not sound right, But it is how I do it now. I fill them with water and leave the cap off and freeze them. as the water expands it pushes the dents out. Also loosens the rust. It works for me. Just don't forget about it or you will have a near round tank. Or a split seam. Also before brazing a hole in a fuel tank run exhaust into it for several minutes. This renders the fumes non explosive. Some of you chem students can explaine why this is.
Old Jan 15, 2007 | 11:39 AM
AXracer's Avatar
AXracer
The exhaust replaces the air with carbon monoxide and carbon dioxide which are both heavier than air. Unless the engine is running extremely lean, there is nearly no oxygen left in the exhaust stream. Any minute amount of oxygen left will be picked up by the CO, converting it to CO2.
PS: I don't think I could fit a gas tank full of water into our freezer, and my wife definitely would not think it was a good idea, dents or no dents!
Old Jan 15, 2007 | 12:10 PM
arctic y block
I here that AX. We have several Fish processing plants around with walk in freezers. And most of the time this time of year just leave it outside. I have also used the suction cup dent puller with success.
Old Jan 15, 2007 | 12:19 PM
AXracer's Avatar
AXracer
We see less ice than the Jamaican bobsled team around here.
Old Jan 15, 2007 | 05:33 PM
mamelukesword
Tank Dents
I am going to try the auto body method first. I live in the panhandle of FL so The Ice method may not work. I think the compressed air method will work but I need to find a junk pickup in case I mess everything else up.
Thanks for the input!
Dennis
Old Jan 15, 2007 | 05:42 PM
arctic y block
Be very carfull if ya use air. Wrap a rag around the blow nozzle and just give it a bump. Remember 7 PSI Will blow a 55 gal drum.
Old Jan 15, 2007 | 05:47 PM
56panelford's Avatar
56panelford
Hello mamelukesword, you my want to check out www.gastanks.com , you may find that their prices are quit reasonable, just a thought.
John
