head bolts
Old Jan 12, 2007 | 09:38 PM
propane32's Avatar
propane32
head bolts
can anybody tell me where i can find head bolts for my 51 -239 v/8 everybody seems to be out of stock thanks clyde
Old Jan 12, 2007 | 09:43 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Clyde,
You might be able to find something tht will work here;
http://www.mcmaster.com/
Thats where I found my exhaust manifold bolts, about 3 times cheaper than Summit, PAW, Speedway, JEGS, etc
Bobby
Old Jan 12, 2007 | 09:59 PM
CharlieLed's Avatar
CharlieLed
http://www.classicautopartsgroup.com...=P06-10170-005
Old Jan 12, 2007 | 10:12 PM
'50 PHATTY's Avatar
'50 PHATTY
When I was looking for them a couple of weeks ago, the only place I found that had them was Red's Headers. At least they had the small ones. They would have to order the long ones from somewhere back east and it would take 1-2 weeks.
Old Jan 12, 2007 | 11:23 PM
ALBUQ F-1's Avatar
ALBUQ F-1
See Phatty's thread on "flathead leaks" for reasons to buy the correct bolts! Part of the torque spec on these is based on the minimum diameter of the factory-style bolt, which is different than hardware store bolts. What's wrong with your old ones?
Old Jan 13, 2007 | 08:34 AM
propane32's Avatar
propane32
head bolts
ALBUQ F-1 mine look to be streched about midway the bolt otherwise the bolt looks good thanks clyde
Old Jan 13, 2007 | 09:41 AM
ALBUQ F-1's Avatar
ALBUQ F-1
If you mean they are thinner in the middle of the length of the bolt, I think that is the factory shape of them. If the threaded part looks stretched and a nut won't run up them easily, then they are are shot. If they are very rusty, toss 'em. Try measuring the overall length (from underneath the head to end), see if they vary much.
You can't go wrong replacing them, but it would be pretty hard to stretch these without stripping the holes in the block. The deck is not that strong, unfortunately.
Old Jan 13, 2007 | 12:54 PM
4tl8ford's Avatar
4tl8ford
The "Short" Bolts are: 7/16-14x1.94" there are 20 req. for the engine
The "Long" Bolts are: 7/16-14x2.62" there are 28 req. for the engine.
Old Jan 21, 2007 | 11:07 AM
propane32's Avatar
propane32
headbolts
thanks everyone for your response' i lucked up and found some at Baxters in ks. clyde
