Toyota Steering Box Swap 1954 F100
Old Dec 3, 2006 | 04:58 PM
turnrjr's Avatar
turnrjr
The exellent article on this site about this subject said there are threads on the subject here. Can you point me to them? Also a a pictorial from a Mr. Walston about building a pitman arm? The search option isn't working at this time. Thank you.
Old Dec 3, 2006 | 06:19 PM
51ford fan's Avatar
51ford fan
Welcome to the forum look at the link below for that information. Also to find the posts you will need to click on the search button above and search for them. Right now they have the search feature shut down except for FTE Club Members only, so you will have to do your search when the traffic on the site is lighter.
https://www.ford-trucks.com/article/...60_Trucks.html
Old Dec 10, 2006 | 05:47 PM
Walston's Avatar
Walston
Check out my gallery
Old Dec 10, 2006 | 06:31 PM
CharlieLed's Avatar
CharlieLed
This brings up a good topic (especially since I just found an 84 Toyota box for my 56)...has anyone grafted the lower section of the Ford arm to the upper section of the Toyota arm? I am not a certified welder but it seems like it should be possible...
Old Dec 10, 2006 | 08:35 PM
4tl8ford's Avatar
4tl8ford
Check this out
http://www.geocities.com/zeener96/toyota.htm
Old Dec 10, 2006 | 09:00 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
I mounted the toyota box ahead of the axle in my 49 (its a long story). When it came time to make the pitman are I took the stock toyo unit, cut it in half, spun one end 180 degrees and welded it back together. (yes I had a certified welder do the welding and I gusseted it a bit)
When I was first thinking of it I read the article that Dick just posted and was going to go that route. I've slept alot since then and for the life of me can't remembe why I didn't
Bobby
Old Dec 11, 2006 | 05:22 AM
Walston's Avatar
Walston
The original pitman arms are cast, and cast does not weld the greatest. If it cools too fast it can become brittle and the last thing you want to have happen is to have it break while driving................AHH NO STEERING!!!!!
So that is why we embedded the cast components in a piece of plate. That way the cast is surronded by plate and brittleness is not an issue.
Old Dec 11, 2006 | 07:28 AM
AXracer's Avatar
AXracer
IMHO the work and safety aspects of building your own pitman arm just doesn't make sense over buying one already made like Mid Fifty sells unless you are going with the manual steering box. I had to split the Toy pitman arm and shaft nut to get them off the Toy box. I believe the Ford pitman arm is forged rather than cast tho.
PS: Welcome to FTE!
Old Dec 11, 2006 | 04:02 PM
Walston's Avatar
Walston
AX
I agree, when we built ours, there was not one available for a 57-60. The arm is different from the earlier years. I believe CPP makes one now very similar to the one we made.
As far as the cast verses forged, you could be correct.
Old Dec 11, 2006 | 04:46 PM
AXracer's Avatar
AXracer
Walston, I wasn't being critical of you building your pitman arm, I knew why you did it.
I was replying to the original poster about building his own by combining the Ford and Toyota arms.
Old Dec 11, 2006 | 05:49 PM
Walston's Avatar
Walston
No worries, people from Ohio are not sensitive.
Old Dec 15, 2006 | 06:50 PM
turnrjr's Avatar
turnrjr
I love this place! What a great resource. Thank you.
pirate4x4_camo
May 1, 2021 11:59 AM
Im50fast
May 22, 2016 09:33 AM
46fordtruck
1947 and Older Ford Trucks
Apr 24, 2016 10:53 PM
imlowr2
38
Oct 25, 2015 11:02 AM
Vsanzbajo
Jun 17, 2014 04:33 PM
