1978 - 1996 Big Bronco
Steel Coolant line
Old Oct 9, 2006 | 12:33 PM
Flagtown FD's Avatar
Flagtown FD
Steel Coolant line
Just finished a 302 swap on my '89 fullsize bronco and when i took the original motor out i had to cut the steel line that leads from the radiator to the transmission oil cooler...I picked up a 5/16 steel line and when i threaded the fitting into the radiator there was still room for the line to move back and forth. i couldnt find the original adapter so i tried a couple of stores looking for a longer threaded one but no such luck... Let me know if you have any ideas...
Thanks
Old Oct 9, 2006 | 03:27 PM
greystreak92's Avatar
greystreak92
Flagtown FD,
Welcome to FTE and the Big Bronco Forum. We will endeavor to get you the most accurate info we can muster.
So you are dealing with a fitting on the flared end of the tubing I take it that is too short to run down tight enough to clamp the line into the fitting. If you can't find a fitting that is long enough that fits a flared piece of tubing, you might be able to cut the flared end off and use a compression fitting on the line instead. I'd only do that as a last resort simply because in my experience, compression fittings don't seal nearly as well as the flared tubing and end fitting.
Old Oct 9, 2006 | 04:37 PM
94broncoxl's Avatar
94broncoxl
Got mine at Ford, they weren't too expensive and I saved the headache of running all over. They had the in stock as well.
ct50f1
16
Jun 5, 2025 10:57 AM
69 f250 cmpr special
Mar 29, 2014 05:58 AM
Jeff and Nicolle
Jan 7, 2014 02:20 PM
tlambert
Oct 13, 2013 10:39 AM
bigTEE56
Jun 17, 2013 09:08 PM
