1978 - 1996 Big Bronco
92 302 V8: Engine Clean up/ Overhaul questions?
Old Oct 8, 2006 | 08:26 AM
muckypaws's Avatar
muckypaws
Hi Folks,
Not posted here for a while but having come back from holiday I feel refreshed and motivated to tackle the oil leaks from the Valve Covers and other engine issues.
So far so good but I have a few questions that I'd appreciate some help with:
1) Removal of engine loom. Having cleared off the top of the motor I want to remove the wiring loom to make more space. How does one separate the wiring connector on the drivers side wheel arch (near the air box) so I can remove the loom completely. I assume there are some clips or somthing?
2) If I release the bolts holding the fuel lines (hard steel lines) will the lines slip off the top of the injectors or will they need releasing with a tool?
I'm sure there will be more questions as I go on...
Thanks
Simon
Old Oct 8, 2006 | 10:39 AM
fishin machine's Avatar
fishin machine
The wiring harness has a bolt on the back side, 3/8 I think and a clip on each side. The fuel rail can be pulled off the injectors, getting the injectors out of the intake can be a pain. Next time I'll get the tool for it.
Old Oct 8, 2006 | 01:43 PM
muckypaws's Avatar
muckypaws
excelent - I'll give it a go tomorrow when I start again. So far RHS valve cover off and I'm pleased the motor isn't all gummed up with crud like others have been. Just a nice light brown.
Intake manifold/ Plenum is pretty muckys from the PCV and EGR influences.
Rather annoyed that the release kit I bought for A/C & Fuel lines (to change the fuel filter) doesn't contain 1/2 & 5/8 tools for the garter springs on the two fuel lines going to the back of the motor... time to look on ebay!
Simon
Old Oct 8, 2006 | 01:44 PM
muckypaws's Avatar
muckypaws
Are these the right tools to release the garter spring clips on the fuel lines - I get the impresssion they will do..
http://cgi.ebay.co.uk/SEALEY-Air-Con...QQcmdZViewItem
Old Oct 8, 2006 | 02:31 PM
biggreentank's Avatar
biggreentank
Wow Muckypaws, there are Broncos in the UK?? You have to be one of the only ones. I thought Brits hated American made stuff! Go run over some Minis with that thing!
Old Oct 8, 2006 | 02:59 PM
muckypaws's Avatar
muckypaws
Yes, there a few over here. I predict no more than 15 in the whole of the UK. I only know of one other owner in Scotland but have seen some FSBs and IIs on Ebay from time to time in various states from horribly rotten (UK weather isn't good for a US vehicle) to perfect condition 96 which I'd have bought in a instant if I had £5000.
F150s are getting very popular now as a expensive status symbol (now eveyone has Range Rovers or Jaguars!) but they are too long for most UK parking lots. The bronco is a brilliant compromise - manuoerable, spacious, 4x4 - all the benifits of a 150 without the lenght...
Having said that I'd love a F250 Superduty 4x4!!!!!
Simon
yargnitram
Aug 1, 2011 05:49 PM
'94Mesquite
27
Aug 9, 2009 08:29 AM
jorgholio
Apr 13, 2008 07:17 PM
muckypaws
Nov 10, 2007 11:39 AM
muckypaws
Sep 29, 2005 04:03 PM
