ready to restore 53 f100need advice
So...my questions.
1- Engine recs. Without going crazy Im thinking of a Chevy 350 or 302. Keeping in mind right now I just want a decent, reliabe engine. I kind of like idea of 350 because can go anywhere and get parts. I want to be able to take longer trips etc. Right now with a 215 im a little uncomfortable. Is it better to buy a short or long block and add components? Is there another engine I shouldlook at. Recommended website to buy or go thru a place like vintage ford and buy?
2-Transmission....I like manual so what rec and were should I look to get. Certainly has to go with engine...
3-Discs- Well now I get into suspension and ride as well. I see alot of adds on the IFS.. Seems to be a huge range of pricing. Dont want to go insane. Is heidts pretty good? Discs in Front and drum in back?
4-A/C-- Vintage air?
5-Painting...oh my god!! i see can get real crazy...any recs on keeping cost down...Is maaco or someone like that even worth considering...or is that just stupid!
6- Ive prescribed to Classic trucks, bought how to restore your ford pickup but im really looking for building a decent truck that eventually can be taken to next level if I ever want to spruce up more. I dont plan on selling (my wife wont let me!) any thoughts? I have gone to a few local shops and inquired what to do
Ive got a ton more questions...but I will keep simple. Im trying to find links etc for what a good basic driver would be. Ive got about 20K to invest. Im sure there will be alot more stuff I need.Im just trying to start a list and get some rough pricing before I get in over my head. I realize i can't do it all at once but want a good base to add on over the years
Vern
You've really laid a lot on the block, as far as questions, but I feel it is good to have a plan before one starts this big a rebuild.
I am personally a believer that the best build method is to get it to a reliable driver first, then finish it out after driving it for a while. I have done that with mine and the plan changed many times as I did so. Besides, you'll love driving it. If I had a solid truck all together, I would opt to rebuild the flathead, if I could. If you have ruled that out, then the other engine choices come in to play, however, any of thos options will probably wind up being more expensive to do compared to rebuilding a decent stock core.
In considering the engine choice, power and mileage would be my concerns. If you contemplate long trips and don't mind 10 mpg, the 350 will be a lot more fun to punch off the lights. The 302 will give appreciably better mileage and is twice the power these had originally. I would vote for an automatic also. Much easier to install and drive. However, if a stick is what you want the Chevy will give better tranny choices, including OD. But I'm not an expert here.
I would vote to keep the stock front end. Reconditioned, they drive very well. They can be softened by removing a few leafs (no problem because the engines you are considering are lighter than the flattie you pull out). You'll need to replace pins, shackles and put some plastic strips between the leafs, etc. Inexpensive.
The steering will probably stand a look, depending on how drunken your monkey is. I have a Mustang II IFS that came in the truck when I bought it, but knowing what I know now, I wouldn't install an IFS. There are disk brake setups that bolt on to the stock solid axle and power steering is available either by going to a Toyota box (a popular option with some folks here) or a ram assist kit.
Vintage Air has pretty much the concensus agreement as a very good system.
Paint. Now here is where every build budget has the opprtunity to look more like the kid's college fund! Like you, I struggled with this. I am building a driver (on a budget) and wasn't looking for the perfect show paint job. I checked Maaco, One Day and other local shops. Prices (in So Cal) ranged from 3k-6k. If we were building a slab-sided something (Camaro, etc), they would be a decent choice. But, our fat-fendered trucks don't paint well all together. The paint won't cover well going down into the corners between fender and body/bed, etc. They really need to be painted in pieces and reassembled. NONE of these local places would do that for that price. "The pieces take up too much room in the booth" was the reason they gave.
Recognizing that it is the prep work that makes or breaks a paint job, I chose to learn how to do that and am doing it now. It takes a while to get the hang of it, it is messy, it takes patience (a lot), and, if you don't like how it looks, you can grind it off and do it again until it's good. (I know this well). I will paint my 56 myself in my garage this winter. And, actually, I'm getting pretty excited about the idea.
Tons of questions is good. Please just make sure to ask some simple or dumb ones as that's the best chance many of us here have to look smart.
First of all you have a good looking truck now.
If it were mine I would throw out the stock suspension and install a IFS.
Before you make a choice price out both what Randy suggested and what Vern and I suggest. May find out one of them isn't as cheap as you might think.
A sbc is the cheaper choice but a 351W/AOD would/will work great.
Vintage air is a good choice but it's not a bolt in.
Having said all that I would keep the outside just like it is except have it about 4 inches lower and a set of W/W radials.
They gave me prices of $8500.00 on up for a paint job that was suppost to be equal to production. Thats why mines in black primer (done in my garage after I failed on the paint job).
What ever you do just remember it's suppost to be FUN.
Chuck
2.For a manual tranny I'd recommend an OD unit for performance around town and economy/reduced noise and wear on the highway. That would mean a T5 5 speed (world version) or T56 6 speed (double OD, HD) with a rear gear ratio in the 3.0-3.7:1 range.
3. Power disk brakes front drums rear, YES! Need to decide underfloor or hanging pedals (best with manual tranny IMHO) Don't want to go insane with suspension then forget the IFS, The beam axle can be made to give 90% of the ride and handling for far less money even including the Toyota PS addition and an aftermarket tilt column and wheel.
4. Vintage Air makes a good unit, I like the fact it can be ordered with fittings that can hide the hoses. I have an Old Air unit in my truck that's a bolt in replacement unit.
5. Paint ???? The new 2 stage (basecoat/clearcoat) are pretty hard to mess up if you have a large enough compressor and buy a GOOD HVLP spray gun. The quickie paint shops can do a decent job if you give them a fully stripped (glass, chrome, interior, bedfloor etc.) and preped ( all bodywork completed, primed and surface puttied) vehicle. The reason they're cheap is in the (lack of) prep work. You can solve the problem Randy mentioned by hanging the fenders in place with long bolts and spacers to open up the areas between without them having to deal with separate parts.
Depending on how much work you can/will do yourself and how crazy you go you are looking at spending $10-30K+ and 1- 10 years, with mid range of those numbers being about a realistic average for a dedicated enthusiast using good used major parts and doing a good part of the work themselves.
engine
1- wow...gas mileage..hadnt a clue. If you had to guess on a 302 what would mpg be. OR am i better getting a larger engine in case I ever want to change look etc..driver to whatever and live with low mpg?
2- whats diff between long block and short?
3- Would i save more $$ if i got one over the other and added components myself? I am mechanically inclined and just need to get some advice and I do have some neighbors that would assist
4- Not sure about going to wrecking yard and pulling and redoing...that probably is out of my scope and talent.
5- were is best place to get the engines? have any recommendations?rebuild vs new?
6- if i got a short or longblock what would your best guess be dollar wise for the add ons..(distributor, waterpump etc) assuming not going crazy.I can always add some of that stuff later on if I want...i assume.
this would be a good start. Looking back at all the classic trucks mags...do seem to see alot of 350's
again thanks....if you guys are willing to help a bit I will post just a few more replies until I get a list of the most important stuff out of way (front end, discs, backend,power brake and steering). A/c is done...vintage air. Funny about the painting...i was thinking originally about getting one of the saito (i think thats right) guns and doing myself. But I will continue that discussion later...I really want to thank you guys for helping...this can be a little overwhelming...but fun!!
$ to complete longblock ~ 1000.00-1500.00
Gas milege will depend a lot on tranny (OD or no) rear end ratio (higher gearing i.e. numerically smaller = more milege but less performance) tire size, and (especially) driver's right foot. Our trucks weigh very close to 2T and have aero of a barn door, IMHO 302 is marginal size engine for daily driver, OK for a cruiser. Most 302s were built for economy during last gas crisis and had poor flowing heads designed for 2 BBL carb.
It takes a fair amount of $ aftermarket/high pro parts just to = HP of a stock 351W, and will never dependably = a slightly warmed over 351. IMHO You'll be money ahead starting with the 351 unless you happen to have a perfect donor vehicle already sitting in the yard and a tight budget.
Too many new enthusiasts jump into their first vehicle with both feet and are quickly overwhelmed and eventually lose interest and enthusiasm. Sounds like you have wisely started with a sound foundation. I'd suggest you concentrate on just one project at a time as needed/ wanted and keep the truck drivable as much as possible in between.
One thing you didn't mention is the rear end. The stock rear end is servicable for a while, but if you are going to put a V8 in it you might want to plan on changing it out for something stonger with an appropriate ratio while you have it down for the engine swap. Take a look at the top of this page and click on the articles and specs tab for a wealth of info you'll find useful/informative.
Pictures: look at the sticky post at the top of the topic page on how to set up a personal gallery where you can put all the pix you want. If you click on any user's name in their posts you can then look at their gallery as well.
OOPS! what happened to that topic???? You can click on user CP at the top of the page and edit gallery in the left panel. Follow instructions to set up gallery.
While you're in there you also may want to add an email address to your profile so people can send you offline info.
If your stock setup suits you engine wise, that is, has enough power and economy for you, your best bet would be to keep it. You can rebuild yours or get another block without spending a lot. I have an extra, and know of a couple of others - having yours or one of those rebuilt would be in the $1k to $1500 range. When I started mine the local NAPA store offered me one exchange for $850, but that has been a few years ago.
If you want to hot rod it, you can spend any amount and buy whatever horsepower you want. I like the 302 V8 and AOD combination, but am going with the EFI 300 six with a truck 4 speed tranny in my 59 as I intend to work it.
Probably be a good idea to have local help and support. You can contact me offline at your convience. I just set up to do private emails...we can talk on phone or over email Would like more info on meeting dates etc.
thanks!
and you can join the group (or not) if you wish by clicking on the image in my signature.
