1951 Hood Removal
Old Sep 6, 2006 | 10:32 AM
panningbros's Avatar
panningbros
1951 Hood Removal
What is the best way to remove the hood on a 1951 F2? There are the 2 spring loaded brackets on the front face of the firewall and the 2 side brackets that have 3 nuts on each that are accessable from inside the cab. Is it best to leave all these brackets on the hood when you remove it? It would be nice if this hood would open up a little further. I'm not as small and limber as I used to be! Thanks in advance.......... Dave
Old Sep 6, 2006 | 11:34 AM
52merc's Avatar
52merc
Here is how I removed the hood on my '52 by myself. I opened the hood and supported the nose. I unbolted the side hinges from the hood. I then removed the support and lowered the hood. The hood can now be slid forward. With the hood slid out from the firewall the sprong loaded brackets can be unbolted from the firewall. The hood can then be lifted off of the truck. Mind you when I did this I was disassembling for a completed restoration so I wasn't concerned about marking paint etc.
