99 expedition fuse problem
Old Aug 5, 2006 | 12:24 PM
larz697's Avatar
larz697
hi all here is my problem wife broke down with an exploded battery. so works out the alternator was overcharging,prob is now half the stuff on the vehicle wont work.such as power windows,overhead lights,running board lights,rear brake and blinkers only.have checked and replaced all blown fuses both in fuse box and power box.got 4 fuses which have no power to them at all, Any ideas at all would help
thanks larry
Old Aug 5, 2006 | 02:26 PM
87 XLT's Avatar
87 XLT
OUCH, that must have been a real mess under the hood.
Sounds like a blown maxi fuse.
Take a look at your wiring diagram & see which maxi fuse provides voltage to the fuses with no voltage..
Or look at the list of fuses in your owners manual, it might say something like power to this fuse is from maxi fuse such and such.
Good luck with it.
Old Aug 5, 2006 | 02:51 PM
larz697's Avatar
larz697
have no owners manuals sorry to say been all over the web looking and found nothing
Old Aug 5, 2006 | 02:52 PM
larz697's Avatar
larz697
if u have an idea where this maxi fuse is would help me narrow down my search
Old Aug 5, 2006 | 04:18 PM
87 XLT's Avatar
87 XLT
Cant help you much since I only have the factory wiring diagrams-which are worth their weight in gold BTW- for the Fords that I own.
The maxi/large fuses should be under the hood in the PDB/power distribution box.
Pull the lid off of the PDB & check all the maxi fuses.
Old Aug 5, 2006 | 10:19 PM
larz697's Avatar
larz697
all fuses have been checked and none are blown.only thing i cant check is the circuit breakers
Old Aug 6, 2006 | 02:05 PM
87 XLT's Avatar
87 XLT
Well since theres no blown fuses, it sounds like the battery saver relay is the culprit.
The closest wiring diagrams that i have to yours are for a 97 Explorer yours should be wired similiar.
On the 97 the battery saver relay provides power to all courtesy lamps including your dead dome light, the power windows etc..
Odds are if you simply replace this relay, your problems will go away.
Try entering the info for your 99 at autozone.com & see if you can find the location of this relay.
Or give autozone a call, they can probably pull up the location on their computer.
Old Aug 6, 2006 | 04:10 PM
larz697's Avatar
larz697
i tried that autozone site and they have it but no idea of the location if you could help with that i thank you
Old Aug 7, 2006 | 01:10 AM
87 XLT's Avatar
87 XLT
oops, double post
Old Aug 7, 2006 | 01:14 AM
87 XLT's Avatar
87 XLT
The wiring diagram for a 97 Explorer shows the relay behind the center section of the dash. Might be the same on yours, or???????
Looks like your best bet is to stop by a Ford dealer parts department.
Old Aug 7, 2006 | 07:56 AM
projectSHO89's Avatar
projectSHO89
You can download a pdf owner's manual from www.fleet.ford.com free of charge. Look under the MAINTENANCE heading.
Need to know which fuses are missing supply power. There are several that are "sub-feeds" off of other circuits.
The Explorer diagram is so different that it is not useful on this truck. You need the F150/Expy diagram.
Steve
Michaelshawnbradford
Feb 17, 2015 11:12 PM
dennisspeaks
Nov 20, 2011 05:50 PM
T George
Electrical Systems/Wiring
Nov 6, 2011 01:28 PM
rcdriver11
1997 - 2003 F150
Aug 31, 2010 09:24 AM
