Will not shift into 4 wheel high
Old Aug 5, 2006 | 05:56 AM
glong15650's Avatar
glong15650
'03 EXPY checking it over and doing pm I discovered the transfer case would not shift into 4 wheel high, it will shift into 4 wheel low??
Old Aug 5, 2006 | 07:47 PM
glong15650's Avatar
glong15650
Look's like the transfer case gears engage but the light doesn't turn on.
The light does work as it lights up at start up time.
Also the front hubs don't dis-engage when switched to 2 wheel drive.
Old Aug 5, 2006 | 08:36 PM
FTE Herman's Avatar
FTE Herman
Welcome GLong! The expy doesn't have hubs that engage or disengage, the axle shafts are tied to the differential at all times.
I can't however explain why you get 4Lo and not 4Hi.
Old Aug 5, 2006 | 09:22 PM
glong15650's Avatar
glong15650
It's my understanding that the hubs do dis-connect, there are two vacuum lines to each hub, one engages the other dis-engages or one engages the other is a vent to the back side of the vacuum diaphram. 2 wheel high should dis-engage the whole front end.
Old Aug 22, 2006 | 07:54 AM
glong15650's Avatar
glong15650
Relpaced the electrical controlled vacum switch to the front hubs, this seems to have fixed the problem.
The hubs unlock, the driveshaft disconnects, and the 4WH light turns on while in 4 wheel drive.
The switch is located beside the battery box.
Old Aug 23, 2006 | 03:10 PM
Freak4Ford's Avatar
Freak4Ford
glong15650, the part you replaced is that a Ford replacement part? How much is the part? Can you give a better description of what it looks like?
Old Aug 23, 2006 | 09:40 PM
glong15650's Avatar
glong15650
I had the Ford garage do a computer scan for me and they indicated that it was the vacuum switch causing the problem, they charged $87 for the diagnostic.
The switch cost $56 and it was a Ford item. (part # 6L3Z 9H465 B :valve asy)
The switch has two vacuum hose's one going to the front hubs and the other to a vacuum connection on the engine.
There is also an electrical connection with two wires that control the switch.
It's easy to replace, it slides into a bracket on the firewall beside the battery.
I hope this will help.
4 ford owner
Offroad & 4x4
Mar 22, 2011 12:35 AM
DPET5
2004 - 2008 F150
Dec 4, 2010 07:18 PM
mmm_hmm1
Feb 26, 2010 07:31 AM
WhiteZombie
Dec 19, 2009 10:29 AM
ole-red
1997 - 2003 F150
13
Dec 2, 2005 11:32 PM
