Just trying to determine if changing my gear ratio (currently 3.73) on my 1997 E-250 with the 5.4 engine will help with towing. I'm max'd out pulling my 7000 lb travel trailer and was wondering if a swap would take some of the strain off the engine. I've heard of people doing it and they say it will increase your tow rating by "X" lbs. How is this number determined? Is there a rule of thumb that say if you increase from 3.73 to 4.10 you gain so much or from 3.73. to 4.30 you gain this much? ANy help would be appreciated.
Take a look in the towing guide for your truck and check the different ratings for the different ratios. This will give you the answer that you need.
And yes, changing the ratio will definately increase the towing capacity.
Good Luck
I have looked at some towing guides and I can only find the van offered with a 3.73 ratio with the 5.4 engine - there are no other choices to pick from.
Then the gear change won't affect your tow rating. The truck will tow better with the higher gears, but the chart in the owner's manual that lists tow ratings will still show the same rating.
The tow rating, in this context anyway, is just a guideline number. Gear ratios are always a tradeoff between mileage and power. You trade one for the other, generally speaking. You could put 4.10's in, and it will tow better. 4.30's will tow better yet - at the cost of gas mileage.
The question is how much are you looking to tow? With a 3/4 ton van, you have the frame, suspension and brakes to tow up to 10k or so safely. The gear ratio that you pick depends on how fast you want to go up hills. With a 5.4 towing 10,000 lbs, it's going to struggle no matter what gears are in it, but the lower the gears the better.
As long as the frame, suspension, and tranny are good enough, you can increase your towing capability. I don't know youir specific car, but at least with a Bronco, trucks with the relatively rare 4.11 gear had higher tow rating.
