New TorqShift-G and Gear Ratios for the 6.2
No new information about the new TorqShift-G, except for a few words from Ford reps saying it "fits the 6.2 gas engine" better than the previous generation transmission.
With no changes in the gear ratios offered - 3.73 and 4.3 - can those of us making an early order assume that both gears will see increased TQ/HP numbers, with the 3.73 getting a nice little MPG bump?
Any guesses or predictions on what we will see this summer?
I've been seeing some Ram Tradesman Quad 4wd Cummins being advertised for $41K ($52K MSRP). Has the basics that I want: Power windows, Bluetooth, front cloth bench, backup sensors/cam.
I'm at the point where I want a low $40's Diesel Quad 4wd truck. Hopefully a '17 F-250 XLT can be had for this in another year.
Something like this for ~$40K new is very tempting:
New 2016 Ram 2500 Tradesman For Sale in Caldwell Near Boise, Nampa, ID | Vin:3C6UR5CL5GG113224
The 6.2L is definitely getting some kind of a bump - could be just torque, could be just horsepower, but it will be something. I doubt it will be huge, but really, Ford basically doesn't need to do any further development - the 2014 F-150 had this engine with 411 / 434. That would definitely be a "nice" bump, but I'd fall out of my chair if it were more than that.
I'm guessing 400bhp and 420lb-ft will be the numbers.
F-350's will get nothing other than that bump. F-250's will get the "G" transmission, which is essentially a beefed up 6R80E from the F-150, in line with what GM and RAM do with their gas HD models.
The "G" trans will undoubtedly be lighter weight, and probably requires less engine horsepower to run the pump - everything inside is a little smaller and lighter. That will make the 250's probably even quicker than ever for the gas trucks, anyway.
I placed an order about 3 weeks ago for a gas 2017 F-350. This last week I've been fighting with the notion of calling the dealer and asking for them to switch it to a diesel.
Yesterday, on my landscaping route, my 6.7L regenerated three times because the trips were not long enough to finish. That irritated me - not everyone is on the highway all the time. Then last night I did take it for an Interstate run to try to clear out the regen - and of course, it never did regen, which means it probably cleaned the DPF just enough to not trip it...until some other inopportune time.
So for now, I'm staying gas. There is no doubt that it is a solid engine with no worries at all. The 48.5 gallon tank and the dual batteries I ordered make this a fairly attractive truck - but I'll miss the diesel sound and pull.
Then, this weekend, we took the fifth wheel out for the first trip of the year. Set the cruise on 65 and just sit back and enjoy the ride. No drama, just the diesel pulling like it always does. Man, I'm getting a diesel next!
So, for the return trip, I fueled up just before heading home. Pull in the driveway, and the gauge read 9.5 MPG (and it usually reads .5-1 MPG higher than actual) and I thought...why do I pay so much money for a diesel, put in more expensive fuel, pay more for maintenance, only to get *****ty fuel economy on top of it all. Then, I remembered passing the slowpoke on the highway, going up a fairly steep hill, with 9500 lbs in tow, and STILL gaining speed with plenty of go-pedal left (no, this isn't the reason for the bad MPG, it's normal for this 6.4L beast).
This decision will chew on me for the next two years. But hey, at least I get to wait and see what gasser is next, and if they slap a couple turbos on it before I decide.
Yep, if you hold off even a little while, you'll be subject to even more info which might help sway your decision - will the gas engine power bump make it more enticing, combined with the upfront savings? Or will the upgraded diesel's power output be too much to resist? If you wait the two years you're talking about, a lot can happen. Your current diesel could have a very expensive problem which completely sows up the decision to buy a gas. Or, the "upgraded" 6.7L could be problematic - also sowing up the decision for a gas. Conversely, the new diesel could be spectacular...with Ford designing a better, less intrusive regen operation. Maybe the new engine will get much better fuel economy. These things would really push you towards the diesel.
I'm still torn - when I bought my current 6.7L, diesel was 40 cents a gallon more than regular unleaded. Right now, it is 5 cents a gallon cheaper.
For now, I'm going to stick with the gas truck. $60k was the budget max I set for myself, which is still crazy for a pickup truck, but right now that is where I am at on x-plan pricing - exactly $60k. I see some of these guys buying $70-80k trucks...more power to them. I'll be done trading every year for quite some time, as well.
Personally, I'm hoping for a twin turbo gasser with a 10 speed before I buy.
I've even considered going to a F-150 3.5 EB but I just love a larger HD truck.
I'm towing 8k max, so it's not like I need a huge truck. But being in the mountains, going up a grade is frustrating in my 6.2.
I'm just going to see what new diesel I can get for $40K at the end of the model year and see who gets my cash. Looks like Ram for now. That's my max for a new truck, which makes it easy to know what I can buy. Not much!
Do you have the 4.30 gears in your current 6.2L?
