55 F10 Brake Conversion (newbie)
It does need some TLC and the first thing I want to look at replacing / updating / repairing is the brakes. My problem is that I'm not really sure where to start, I've been reading some but I'm still pretty much in the dark.
What I want to do is replace the 4-drums with discs. I am looking for Kits but can't easily find what I am looking for, or don't exactly know what it is I'm looking for. The truck is stock, so far.
I'm sure this is a common update that you guys have done so can you point a
in the right direction? What I've gleaned so far is: I need is a front kit, a rear kit and a master cylinder, then I connect it all up with the lines and valves, etc... Ok, I admit a little oversimplified, but that's the idea, I think.I see options for things that I don't know yet or quite understand such as :
- Big Bearing Ford vs. Small Bearing Ford
- Bolt Patters 5x?
- 9" Rear End (This is what's in a '55 F100, correct)?
I know some of this is fundamental, but I do plan on returning the favor by documenting my projects for the FTE site as a thanks and resource for future enthusiasts!
Thanks in advance,
-Jason
- Bolt Patters 5x?
Thanks in advance,
-Jason
I think what you might want to do is replace the original rear end with a 57-72 nine inch which will have a 5 on 5.5 pattern...although if you are intent on having rear disc brakes you can use a late Explorer 8.8 rear with a 5 on 4.5 pattern. It's not a bolt-in like the nine inch but several here on the forum have done the swap. Also, you can change the bolt pattern for the 57-72 nine inch to 5 on 4.5 by using passenger car axles or have the truck axles re-drilled ny a machine shop. If you intend to keep the straight axle in front I'd look for a kit that uses rotors that will give you a pattern on the front to match whatever rear you use. If you have plans to convert to an IFS then don't waste your money on a kit for a straight axle because whatever IFS you use will already have disc brakes.
Vern
Oh, and welcome to the forum and the insanity!
Here is another link for brake stuff; http://www.ecihotrodbrakes.com/ When doing the front disc swap you can chooe the bolt pattern you want 5 on 5 1/2 or 5 on 4 1/2. The easiest thing to do is to roll a 57-72 9" under the rear (on my 49 the 9" from a 1960 was a direct bolt in with the exception of shock mounts) adn stick with drum brakes in the back, get the front disc kit from one of the many suppliers and enjoy your gorgeous truck
Bobby
Bobby
Vern
