drum to disc for a '53 F250
Old Jul 5, 2006 | 05:51 PM
bsully728's Avatar
bsully728
Anyone had any luck finding drum to disc brake parts for a '53 F250? They are all over for the F100, but not the bigger trucks. Are there any later year swaps that may work?
Old Jul 6, 2006 | 03:42 PM
AXracer's Avatar
AXracer
AFAIK the 53-56 used the same front axle in the F100, 250 and 350, just used heavier springs in the bigger trucks. The disc brake conversions should fit all 3.
Old Jul 6, 2006 | 05:56 PM
bsully728's Avatar
bsully728
The axle may be the same size, but the spindle is a different diameter. All of the kits that I have found the spindle diameter is .813, where mine is 1.315.
Old Jul 6, 2006 | 07:12 PM
AXracer's Avatar
AXracer
OK, then why not swap in a F100 front axle or spindles?
Old Jul 6, 2006 | 08:24 PM
f250red's Avatar
f250red
I am doing the same conversion and was told they were interchangable. the after market parts catalogs list the same wheel bearings for f-100 and f-250,mine is a 54 f-250.hope to see more info on this site also info on price and quality. RED
Old Jul 7, 2006 | 09:41 PM
1954F250's Avatar
1954F250
Need 3/4 ton brake drums!
I am interested in any of the 3/4 ton 12"" x 2" brake drums if you guys are going to get rid of them and they are in usable condition. Let me know if you want to part with them.
Kevin
Old Jul 11, 2006 | 04:17 PM
bsully728's Avatar
bsully728
Red
Where did you find the F250 parts? I'm sure that the spindle diameter is different from the F100's to the F250's.
Old Apr 14, 2021 | 07:42 AM
mwf250's Avatar
mwf250
Red,
I have a 1953 Ford F250 with a brand new 9 inch rear end with disc brakes with a 4.75 lug pattern. I would like to put disc brakes on the front —I’ve taken it apart and got rid of the drums, they say the king pin is not the same on the F100 as an F250 so the kit offered to convert it over will not fit. I am stuck. what did you do?
Old Apr 14, 2021 | 01:35 PM
abe's Avatar
abe
mw, this thread was last alive in 2006. Red might not check fte or be an active member. Start a new thread.
I see you are rather new, so welcome to FTE the best Ford truck forum on the World wide Web!
Old Apr 15, 2021 | 12:16 AM
52 Merc's Avatar
52 Merc
Originally Posted by mwf250
Red,
Again, who is "they"? Unless you don't have an F250, or an F250 axle, any brake kit that fits a 53 F100 will fit on a 53 F250. Checking the Ford parts catalog, the axles, spindles, spindle bolts (aka, king pin), and spindle bushing and bolt rebuild kit, are the same. And what does the king pin size have to do with anything? There is no correlation between the king pin and the brake kit. The caliper bracket bolts onto the spindle where the drum brake backing plate was, and the rotor/hub slides over the spindle shaft. Done deal.
If your chosen supplier doesn't want to sell you a brake kit, I'm sure there are other more reputable and knowledgeable vendors who will gladly take your money, and give you better tech support and customer service.
Old Apr 15, 2021 | 09:12 AM
mwf250's Avatar
mwf250
Thanks, Wayne for the confirmation. I do have an 53 F250. The rep from the company I called threw me off with the Kingpin being an issue related to the brakes. I guess it doesn't matter which company name -- your right I will look around for other manufacturers.
I thought the issue might be with the grease zerk.
Sorry for pulling up an old thread. I appreciate your reply.
Michael
Old Apr 15, 2021 | 10:13 AM
8pack's Avatar
8pack
I am GLAD you revived this thread. I am trying to figure this out as well fir my ‘55 F250 and am struggling.
Please keep updating here as you gather information! I will do the same, but I definitely need to solve this problem and would love to figure it out with you!
mwf250
Apr 13, 2021 06:31 AM
NASHMAN619
Aug 10, 2019 09:26 AM
steve664x4
Mar 22, 2006 09:00 AM
Ironwolf21
Nov 1, 2002 10:04 AM
FE427TP
Apr 26, 2001 09:03 PM
