2003 fx4 light vibration
Old Jun 28, 2006 | 05:57 PM
barrysfx4's Avatar
barrysfx4
hi new to site i have 2003 fx4 offroad i purchased used october of 05. currently has 33519mi on. when i first got everthing was perfect then approx 1,000mi later developed very slight vibration from 58mph down to 48mph on decel only in 5th gear [manual trans]. at same time trans has slight noise in morning in 2nd gear [ cold ] these 2 problems came at same time returned to dealer 2 different times rebalanced tires checked driveline angles etc cannot find anything . it seems to be trans problem as it only occures in 5th gear down shift to 4th vibration gone. push clutch in vibration gone leave clutch out vibration returns. any ideas keep in mind this is not eccessive but is annoying. seems to me that it might be bearing going bad in trans? truck just out of war-n-t but problem logged with ford. i do have faith in this dealer. thats not the problem but ford will not allow them to pull trans to check on a hunch. ok any ideas ? sorry for long post just trying to provide enough info thanks in advance
Old Jun 28, 2006 | 07:25 PM
Alan D.'s Avatar
Alan D.
First Mis-steak. you trusted the dealer. on to the problem. Think maybe a fluid change wouldn't hurt. but consider this, the speed of the tranny might be combining with the resonence of something else to create your schimmy. my truck has a similar problem since i regeared it. dropped the tranny, checked whole system over after about 1k miles and no damage to anything. if your really concerned you could get the bearings and the gear replaced, but i think you may have broken the front end in, picked up a viberation, and with the viberation, and the tranny viberation form the gear, the two combine and make your problem. i dont have any adice that wont cost you anything, except let it be, but that may be dangerous.
Old Jun 29, 2006 | 07:03 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome barry, to Ford Truck Enthusiasts!
See you on the boards. ….
Old Jun 29, 2006 | 07:32 PM
barrysfx4's Avatar
barrysfx4
no problem with dealer they have went to great lenths on other problems with other cars/trucks i have purchased from them. problem is not front end vibation only in 5th gear from 58mph to 48mph on decel only. clutch in no vibration clutch out vibration only in 5th gear .
Old Jun 29, 2006 | 07:36 PM
Bob Ayers's Avatar
Bob Ayers
Do you get the vibration with the tranny in neutral, and the clutch out?
Old Jun 29, 2006 | 07:54 PM
barrysfx4's Avatar
barrysfx4
no vibration only in 5th gear clutch out clutch in no vibration.
Old Jun 29, 2006 | 08:02 PM
Alan D.'s Avatar
Alan D.
First-off, i'm moving to Maryland. Secondly, did you try a front end alignment? it could help, alot.
Old Jun 29, 2006 | 08:03 PM
Bob Ayers's Avatar
Bob Ayers
It sounds like the pilot bearing and/or tranny input bearing are bad, causing the input shaft to go out of alignment.
Old Jun 29, 2006 | 08:13 PM
barrysfx4's Avatar
barrysfx4
ok i can buy pilot brg / input shaft brg bad common problem?? how do i go about getting ford to try to solve problem? my dealer is contacting service rep to try to help but they say ford has cut back on service reps and there territory has become very large.
Old Jun 30, 2006 | 05:29 AM
Bob Ayers's Avatar
Bob Ayers
You shouldn't have to buy it, your warranty should cover it since the problem is documented at the dealer....
Old Jun 30, 2006 | 02:03 PM
RangerPilot's Avatar
RangerPilot
I think he said his warranty was out.
If you go in the tranny to do the pilot bearing you may as well do the clutch and slave as well...save yourself time later. My thoughts anyways.
RP
Zach
