What Egt Temp Are You Gettin?
Old Jun 21, 2006 | 05:24 PM
tdmeltdown's Avatar
tdmeltdown
Question What Egt Temp Are You Gettin?
Hello All
I Just Installed My Egt, I Put It In The Down Pipe. It Was Easier Then Drillin The Manifold.
It Idles At About 400f And Cruises At About 550f, On Hills Or When I Stop It It Gets Up To About 700f
Alto Im Puttin My Quadzilla In This Weekend I Cant Wait To See The Power And The Mpg Increase On The Different Settings.
What Do You Guys Think About Where I Put The Egt Gauge?
Thx
Meltdown
Old Jun 21, 2006 | 05:52 PM
phish555's Avatar
phish555
If I understand you correctly, you installed the egt probe post turbo. I believe it will read about 200 degrees cooler than if you would have installed it pre-turbo.
I installed mine in the manifold, it was cake. On the highway, with only slight hills, I read about 900-1000. With my slide-in camper, (see gallery) I've never read any higher than 1150. Flatland, cruise control on at 70mph, about 700.
Phish555
06 F250 ps superduty
Old Jun 21, 2006 | 07:13 PM
JMullens's Avatar
JMullens
Meltdown,
I also have my gauge installed on the downpipe. I run an SCT street tune and I'm seeing about the same temps as you. The difference with a tuner is at WOT. The EGT's really climb fast with the tuner dumping all the fuel in. Phish is correct in that the EGT's will run about 200 deg hotter pre-turbo. My gauge is color-coded, green till 850 then yellow then red at 1100. When you get your programmer watch that gauge closely and if you see it going north of 1000 back your foot off. Also, watch the rate of climb. I have kept it in the green and even yellow for very short periods and have had zero problems.
Old Jun 21, 2006 | 08:10 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
The reasoning for drilling and installing in the manifold is so one can shut down or get off throttle BEFORE the temps get too high for the turbo. Some have actually put one both pre and post turbo.
Old Jun 22, 2006 | 07:19 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
I have stayed at 1275 for over two hours pulling through Utah.
Post-turbo.
Old Jun 26, 2006 | 12:55 AM
SoCalSuperDuty03's Avatar
SoCalSuperDuty03
Tim you are the man... I too have seen some pretty high temps for somewhat long periods. I try not to run my truck over 1350 ever, but I have done it. I have a friend who has run his '03 6.0 1350 to 1380, many, many times, and I have personally witnessed 25 mins. of over 1350 on a long hard pull. BTW the truck has 88,000 hard towing miles, some performance mods, and runs perfect.
Tim
Old Jun 26, 2006 | 06:33 AM
IB Tim's Avatar
IB Tim
I agree 1350 would be my upper limit for extended periods
Old Jun 26, 2006 | 06:23 PM
Customz's Avatar
Customz
I used to see 600 cruising at freeway speed with egr disconnected. 1000 hottest ever under full load. Truck was tuned 04 6.0 with post turbo probe.
Old Jun 26, 2006 | 07:49 PM
6L PWR's Avatar
6L PWR
Mine has run several times at 1580-1600, but only for strip runs for no more than 6-7 seconds. You should see the Autometer Nexus blinking BRIGHT red. Everyone in the stands see's it and asks if I know what I'm doing. lol Of course I don't! Hahahahaha
Old Jun 27, 2006 | 06:50 AM
IB Tim's Avatar
IB Tim
Short runs no big deal, however I run for hours at a time....long long runs.
Matt has run his very high for short periods with no problems also.
Old Jun 27, 2006 | 03:47 PM
Pittsburgh-05HD's Avatar
Pittsburgh-05HD
I have hit 1500-1550 on a 1/4 mile run. Thats even with an aftermarket intercooler but its only for a few seconds. (Pre turbo)
Old Jun 28, 2006 | 01:19 AM
SoCalSuperDuty03
I have seen the pics of Matts pyro dead on 1600.... I think if I ever see the North side of 1400 I am gonna freak!!
Tim
Old Jun 28, 2006 | 10:01 AM
Customz's Avatar
Customz
Tuned 06 6.0 hits 1200 at will. manifold pyro
Old Jun 29, 2006 | 11:13 PM
cabinetmaker00's Avatar
cabinetmaker00
does anyone know the exact temp difference between post turbo and pre turbo ,
I want to get the superchips tuner for my 6.0 and install a egt gauge, but would rather not go through the pain of taking manifold off drilling and tapping hole ,then reinstalling the manifold .
Old Jun 30, 2006 | 09:35 AM
Customz's Avatar
Customz
it varies between load and rpm
