Brake Master Cyl
Brake Master Cyl
I'm installing a reman master cyl for my 72 F250 (front drum, pwr brake), however the fittings on the new m/c would require me to reverse the lines. The current setup had the large reservoir line running to the front brakes. The size of the fittings on the new m/c will only work if I switch them and have the large reservoir feed the rear brakes.
Does it matter which reservoir? I assume there must be a difference since one is twice the size ofthe other.
Thanks,
Bob
Thanks,
Bob
Brake Master Cyl
[updated:LAST EDITED ON 05-Jan-03 AT 11:29 AM (EST)]If you attach the large reservoir to the rear your rear wheels will lock up with just a tap of the pedal. Someone else on here had this problem, rear wheels locking up, and swapping the rears to the small one vice the large one is what fixed it.
Russell
1968 F250 LWB 300-6
FORD=First on Race Day
THE 2003 LINEUP
#88 Dale Jarrett-UPS-Robert Yates Racing
#38 Elliott Sadler-M&M's-Robert Yates Racing
#97 Kurt Busch-Sharpie/Rubbermaid-Rousch Racing
Russell
1968 F250 LWB 300-6
THE 2003 LINEUP
