I had my last modifacation completed on my 1956 Ford F-100 last fall. I had installed: 3 inch dropped front axle from CPP (Classic Performance Products), power brake booster with front disc brakes from CPP, down & centered front springs from Mid FIfty Ford, KYP shocks, front & rear anti-rool sway bars from Mid FIty Ford, and an extended drag link. I didn't want the front wheels up inside the fender wells so the mechanic added an additional leaf to each of the down & centered springs.
Well, everything went well and 10 days later the job was completed. It looks great but I have one problem. The bump steer is unreal . I have to be really hanging onto the steering wheel when I hit any size bump since it really tosses the truck. Does anyone know how this can be corrected? I appreciate it.
After all that change to the steering geometry did you get the truck realigned?
What condition is the steering box in?
Did you make a major change to the wheel offset?
Were the wheels/tires static or spin balanced?
I had the truck realigned immediately after the work was performed, no changes to the wheel offset, the tires were spin balanced, I have power steering (motor & power steering are from a 1956 Thunderbird) and the steering is tight -- no free play.
With the forward centerbolt spring you need to add 1 or more alignment wedges between the spring and axle on each side to get enough caster. You should have at least 2-4 degrees positive caster (top of spindle tipped back) to get the truck to track properly. When you add the wedges, be sure the centerbolt head is long enough to fully engage into the axle. If not Mid Fifty sells extended head centerbolts as well as the wedges. Make sure you have about 1/16 -1/8" toe in as well.
Yes, parallel to the ground at rest.
Do you have any pictures of the SB install, I'm not at all familiar with what that box looks or works like. Wasn't the T-bird a cross steer setup? (output shaft points down and pitman arm swings parallel to the ground)
I don't know why lowering the springs would cause bump steer, a dropped axle is more likely to cause it. With a drastic drop, you may need to reshape the steering arm the drag link connects to (I think Mid Fifty may sell one already dropped) to get the drag link parallel to the ground.
I purchased everything from Mid Fifty including the extended drag link but when it shipped I noticed the axle, power brake booster, and disc brakes were shipped from CPP. That's when I found the following CPP web site about lowering an F-100 and they don't mention bump steer and they used the same parts as I did (www.classicperform.com/tech_articles/F100-Low/F100-Low.htm).
I sent CPP an e-mail regarding the problem and I will check back with Mid Fifty about the drag link part. I thought I read some where that if the drag link from the power steering is at too much of an angle it will cause the problem but now I can't relocate the article.
The drag link has to be parallel to the ground to allow it to swing in the proper arc over bumps, if it isn't your bump steer will not go away.
By the way Z'ing the drag link won't fix the problem, it will still have the incorrect angle between the ends.
I have a 2" dropped axle, reversed eye lowering springs, and my draglink with my Toyota box is near parallel and no bump steer. I don't have the forward center springs because the panels don't suffer from the wheels too far back in the fender well syndrome for some reason. I do have + caster.
