Are an 88 and 92 5.0 EFI the same??
Old Feb 11, 2006 | 10:07 PM
Marc150's Avatar
Marc150
Im lookin at a rebuilt 88 5.0 for my truck, best buy so far. I had a buddy of mine tell me that the EFI systems are different and wont work(ie. swap my stuff for that stuff). Also said that my cpu might not work with it. Anyone know if this is true or something?? I wuldnt see why/how they coulda changed, but I aint an expert.
Old Feb 12, 2006 | 03:34 AM
mauicruza's Avatar
mauicruza
I think most 5.0 truck EFIs from around 87 to 90 are basically the same, if they're speed density. But if you mean interchanging with a car type like from a Mustang, then many parts are not interchangeable.
Old Feb 12, 2006 | 10:39 AM
Marc150's Avatar
Marc150
No mustang interchange, just truck to truck. Thats what I thought, maybe the connections might be different but that'd be no big deal. Anyone else know anyhing??
Old Feb 12, 2006 | 11:39 PM
EPNCSU2006's Avatar
EPNCSU2006
It should be fine. If any of the connectors are different, swap the sensor from your old engine to the new one. Use the wiring harness that is in your truck now on the new engine. The engines are the same (though the 92 might have a roller cam, but this makes no difference). Firing orders should be the same on both.
Old Feb 13, 2006 | 06:09 AM
Marc150's Avatar
Marc150
Phew, this is good news guys, thanks ALOT!! One final question, just to be a pita(haha) do I have to use the wiring harness on my engine now on the new one or should that one be good? Again, thank yall very much, I just cant wait to get the ol truck running again!!
Old Feb 13, 2006 | 06:43 AM
EPNCSU2006's Avatar
EPNCSU2006
Use the wiring and computer that are in your truck now.
Old Feb 13, 2006 | 05:19 PM
Marc150's Avatar
Marc150
Alrighty, looks like everything is gonna work and fit fine. Hopefully I'll be getting it soon, maybe this weekend. Thanks again guys, you have no idea how much I appreciate it!!!
Old Feb 14, 2006 | 01:23 AM
Ford_Six's Avatar
Ford_Six
The 92 system used a knock sensor on the rear of the block, above the bell housing that wasn't used on late 80's systems, as far as I know. As far as physical interchange, all should be ok.
If your computer is set up for a knock sensor, plug it into the harness, and strap it up out of the way.
Old Feb 14, 2006 | 08:26 AM
EPNCSU2006's Avatar
EPNCSU2006
The 88 used a knock sensor too. My 87 5.0 has one.
Old Feb 14, 2006 | 12:36 PM
subford's Avatar
subford
Right and all of the 5.0's with FI had the knock sensor.
Old Feb 14, 2006 | 07:33 PM
Marc150's Avatar
Marc150
Well, sunday looks to be the day. Gonna go and look at it and most likely buy it. Ahh, the bellhousing, would that bolt up to my tranny? Mine-E4OD, other engine-AOD. Haha, Im soooo excited!!
Old Feb 15, 2006 | 08:31 AM
subford's Avatar
subford
YES, a 5.0 bolt pattern is a 5.0 bolt pattern. I do not know what years you are talking about so you may have to use the 88's Starter and Ring gear.
I do not know if the E4OD and the AOD had the same Ring Gearn or not.
If you’re current starter has no Solenoid on it then your home free with nothing to worry about.
