watched a torque converter blow up
Old Jan 30, 2006 | 05:51 PM
pintopower8's Avatar
pintopower8
I work for a landscape company and we had to do a job out in the boonies somewhere. we had to climb a big curvy mountain road with an 95 f-250 super duty turbo diesel packed with stone and a triaxle bri-mar trailer packed full of stone.
The truck hit a spot on the climb where it slowed down dramatically and barely climbed the hill. any way like 4 miles later we get to the drive site and look under to see fluid gushing out of the torque converter.
We got it towed and drove him with another work truck to find that the very spot it started to slow going up the hill is where it had happened. 4 miles of tranny fluid
Old Jan 30, 2006 | 07:17 PM
The SnoMan's Avatar
The SnoMan
Tranny likely overheated on climb and started to boil over thru vent then torque converter hub seal failed. You cooked it, it did not blow up. I will also bet that you did not gear down and keep RPMs high are start of climb either. (a great way to fry a tranny with a diesel)
Old Jan 30, 2006 | 07:22 PM
ford390gashog's Avatar
ford390gashog
BINGO!!!!!!!! i have never seen a TC blow but the seals sure do when it boils.
Old Jan 30, 2006 | 09:45 PM
pintopower8
yeah the truck was in a lower gear, it just couldn't take the work. And there was a big gaping hole out the bottom of the converter. That thing was toasted. To get up the hill of the driveway we worked at it wouldn't go up that until we put it in 4-low
Old Jan 31, 2006 | 05:11 AM
ford390gashog
well then it did blow. the hub must have come apart inside
Old Jan 31, 2006 | 05:42 AM
The SnoMan's Avatar
The SnoMan
If the hub had come are, it would not have driven the truck at all and if it had a hole in it there would be no fliud in it at all and nothing to drive it with.
Old Jan 31, 2006 | 04:21 PM
pintopower8
thats what i wondered, but it kept going.
Old Jan 31, 2006 | 07:26 PM
The SnoMan's Avatar
The SnoMan
The Converter hub drive the tranny pump so it has to be intact to move. When you cook tranny and blow converter hub seal, it can leak like crazy because there is pressure behind seal.
Old Feb 1, 2006 | 08:09 PM
Gene W's Avatar
Gene W
pinto,
Were you refering to the inspection plug in the bottom of the bellhousing when you said there was a hole in the bottom of the converter?
Do you have a Pinto with a V8 in it?
Gene
Old Feb 4, 2006 | 07:30 PM
pintopower8
I had a Pinto but no v-8. i never got to do that.
Old Feb 8, 2006 | 12:14 PM
twin66's Avatar
twin66
my bro cooked his tranny, of course it is a chevy (i try to tell him to go to Ford) we was hauling a boat in O/D, (automatic). Funny thing is, thats the second time hes ruined a tranny!
we4turners
Nov 27, 2012 04:50 PM
rick700raptor
Jan 2, 2012 02:42 PM
kdunham
Oct 25, 2011 03:30 PM
clearwatguy
Jun 21, 2010 05:29 PM
Madathlon
Sep 19, 2005 08:38 PM
