223 oil pan stripped, knocked loose
Old Jan 28, 2006 | 10:21 PM
nick65f100's Avatar
nick65f100
So I got sick of my 63 dripping oil from the drain plug and I decided to fix it (aka break it). Any way I knocked the threads that the plug screws into loose in the inside of the pan. So now the plan is to remove the oil pan and weld a nut in the inside of the pan to thread the plug into. Hows my plan? I gotta drive this thing to work on Monday.
Arggh, does working on something always have to create more work? Well, I call it work but its fun even when it makes you cuss!
Old Jan 28, 2006 | 11:48 PM
minishtr's Avatar
minishtr
That's what someone did to mine no problems.
Old Jan 29, 2006 | 08:30 AM
truckfarmer's Avatar
truckfarmer
Consider using a fine thread bolt and nut. I have also made drain plugs for automatic transmission pans with a 1/2" UNF bolt, nut, and 2 nylon washers. I drilled a hole down the middle of the bolt and tapped it for a 1/8" pipe plug. Is exactly what B&M will sell you for about $10.
