1965 352 3 speed
Old Jan 25, 2006 | 04:10 PM
71mopar383's Avatar
71mopar383
1965 352 3 speed
My dad has a 65 352w/3 speed he want to convert to auto I figured a c-6 do I need a different crossmember for this?
Old Jan 26, 2006 | 06:50 AM
jowilker's Avatar
jowilker
I kept the same one in my 66. I suggest that you get a tranny from a pickup to use becasue of the shift arm on the side of the tranny.
John
Old Jan 26, 2006 | 07:28 AM
scamardo's Avatar
scamardo
You won't need a different crossmember but you will need the transmission support beam or whatever it is called. You will have to move it back towards the differential and drill new holes. Not a big deal. Drive shaft will need to be cut as well since the distance will be shorter from tranny to differential.
Since you have shifter on the column (I am assuming) you will need a non-power steering steering column that has a column shifter or you can stay with what you got and install a floor shifter. I did both the C6 conversion and the power steering conversion at the same time and used the donor column which was auto on the column. Just my 2 cents
Old Jan 26, 2006 | 10:36 AM
71mopar383's Avatar
71mopar383
What does this support bar look like does it go under the trans or from the block to the trans and does it need to be from a 65 or from a truck with the same FT/ C6 setup? Is the c6 the only auto tranny that will fit behind these FT motors?
Sorry for all ths ?'s Im a Mopar guy trying to help out my Ford dad...So thanks for the help...
Old Jan 26, 2006 | 10:45 AM
scamardo's Avatar
scamardo
It supports the tailshaft of the tranny, where the tranny support mount is attached. Same setup will work. Mine came off a 73 and worked with my 65, except I did have to drill the holes to bolt it to the frame. A good drill and some oil to keep from burning the bits and there you go.
Old Jan 27, 2006 | 05:48 AM
jowilker's Avatar
jowilker
I think I had to move mine, but the same 3spd support is under the C6.
John
