Sponsored by: Real Truck
Towing 5th Wheel with 2005 Superduty
Old Dec 29, 2005 | 04:47 PM
2003PSDF2504x4's Avatar
2003PSDF2504x4
I have an issue and can't find any related threads, so I will start a new one.
My 2005 F350 SRW 4x4 sits a couple inches higher than my 2003. The wheels are the stock 18" vs. the 16" stock wheels on the 2003.
When pulling my dual axle 5th wheel (after lifting the 5th wheel 3") it still sits about 1/2" too high in the front. I can't lower it any further into the bed of the truck due to the clearance on the bedrail.
I am sure I am not the only one with this issue. I see 2005's pulling 5ers everwhere unleveled which is not safe.
I have posted a picutre in my gallery. Thanks for any help.
Old Dec 29, 2005 | 04:52 PM
ford390gashog's Avatar
ford390gashog
each picture says error! when i click on it.
Old Dec 29, 2005 | 04:54 PM
ford390gashog
if its only 1/2'' then don't worry about it.
Old Dec 29, 2005 | 05:30 PM
busdriver47's Avatar
busdriver47
No more than that will not matter.
Old Dec 29, 2005 | 05:45 PM
Toyman's Avatar
Toyman
Check on your trailer, at the axle where the pivot and shackles moutn to the frame. You may have an extra hole that you can move your suspension to. If you do not there are longer center pivots that you can get, and longer shackles also.
I tow my fifth wheel with the front up about 3", it has not effected how it goes down the road at all. It just doesn't look good to me. I towed all the way to Sturgis SD from Mich. Not a problem at all.
Good luck.....Toyman
Old Dec 29, 2005 | 09:38 PM
Aarkie's Avatar
Aarkie
If I remember right when the superduty first came out a lot of people had the same problem. I think the there is a sb from Ford that has the dealer to remove some blocks that will lower the truck about 2". I do not know where you can find this but you might try calling your dealer. I do not know if it was free or if they charged you for it.
Old Dec 29, 2005 | 11:11 PM
c.f.moore's Avatar
c.f.moore
I tow a 34" 5th wheel with an '05 F350 SRW 4x4. I changed the rear axle blocks from the ~4" tall to 1 3/4"blocks(F250). Make sure that you get a set of OEM blocks from/for the same wheel base that you have, as the blocks are angle set for specific wheel bases.I got the clearence I was looking for (6 1/2" from bedrail to trailer) and a level trailer. I also did not get any driveline vibrations from the change.
Old Dec 29, 2005 | 11:19 PM
black350's Avatar
black350
hi 2003PSDF2504x4
I had a similar situation with my 5th and 2004 F350 - had only about 1"
clearance between the trailer and bed rails with stock setup ( 16" rims
I think; truck has camper package option).
I had the dealership remove the 4" rear blocks completely (with new U
bolts - very important not to re-use the old ones). I then added air bags
(ride rites) to allow for some compensation when needed (and also to
get the rake back when not towing). See my gallery for some pics.
The Ford TSB has them replace the 4's with 2's (a la F250), so you could do
that if you don't need the full 4" drop - I needed all the drop so I didn't
have them put in the 2's at all.
Old Dec 30, 2005 | 12:16 AM
sandjunkie's Avatar
sandjunkie
I flipped the axles on the trailer for added height. This may be an option for your setup as well.
Old Dec 30, 2005 | 09:36 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
1/2" ??? Drive it like that and wait for the leaf springs to settle
Old Dec 30, 2005 | 10:56 AM
2003PSDF2504x4
What is causing that error?
Old Dec 30, 2005 | 11:15 AM
2003PSDF2504x4
Toyman....
I have the mor/ryde at the highest point. The 5er is 15,000lbs and I don't think it will be a good idea to go any higher.
http://www.morryde.com/php/products/...owables/RE.php
IMO, You might want to take you 5er to the scales and meassure the weight on the rear axle. If you are really 3" high, you are not putting enough stress on the truck and too much stress on the rear axle.
Old Dec 30, 2005 | 11:18 AM
2003PSDF2504x4
Thanks for the replies. I think I will try different blocks in the rear.
