Need help bad engine went to heaven.
Old Jan 4, 2002 | 08:18 AM
bluemustang's Avatar
bluemustang
Was driving down the road about 80 and the oil pump stopped working, the oil light did not work. The engine went BYBY. I'm going to get a rebuilt one and I need to know if any one has a diagram of all the Vacumm lines, because I know I will miss a few. The truck is an 1975 F100 with a 360 in it.
Also I got some numbers off the rearend can any one tell what the rest of the numbers are. I figured it's a 9inch with th 3.00 gear.
TAG
WDM-AG1 4K8
3.00 9 3448
Old Jan 4, 2002 | 08:43 AM
390fe's Avatar
390fe
I think your best bet would be to put masking tape on everything that you take off the engine and label the pieces of tape. Then in a notepad, write down what labeled piece goes where. Get what I'm saying?
You are correct on the gear ratio.
Jason Kendrick
Old Jan 4, 2002 | 09:16 AM
dinosaurfan's Avatar
dinosaurfan
Blue, you could help yourself a bunch by taking some pictures of the original engine before you take it out. Got a camera handy ? DF
Old Jan 4, 2002 | 09:26 AM
bluemustang
I plan on taken pictures and marking everything, but there are a few lines that are plugged and missing.
Old Jan 6, 2002 | 04:06 PM
Trail_Rider's Avatar
Trail_Rider
1 vaccum line to the vacuum advance and one to the brake booster if you've got one.
Trail Rider
Old Jan 6, 2002 | 04:20 PM
xcopterdoc's Avatar
xcopterdoc
