87 F250 (302) revs up when I hit the clutch
Old Dec 9, 2005 | 01:41 PM
psu927's Avatar
psu927
it is a 4 speed manual and whenever I go to shift, the rpms go up for about a second then go down, what is my problem?
Old Dec 9, 2005 | 03:45 PM
Kemicalburns's Avatar
Kemicalburns
could your foot be slightly on the gas at the time. i know when i shift in my car i tend to give a little blip of the throttle as im shifting.
Old Dec 9, 2005 | 09:04 PM
psu927's Avatar
psu927
no, that's not what it is, I check and double checked that. I'm sure that is not what it is.
Old Dec 10, 2005 | 06:22 AM
Nitramjr's Avatar
Nitramjr
Try cleaning and lubricating all your throttle linkages. They could be a little gummed up and with the cold weather everything could be a little sticky.
I had the same problem with an '85 F150 and with an '87 Bronco - a clean and lube solved it on both.
Good luck.
Old Dec 10, 2005 | 02:17 PM
psu927's Avatar
psu927
i thought about that, but why, when I throttle up when not in gear, does i act normal? Just trying to get this figured out. It's not really a huge deal even, but I am getting -2 mpg beause of it.
Old Dec 10, 2005 | 02:40 PM
Ford Truck Racer's Avatar
Ford Truck Racer
My truck does the same, I have noticed if I shut it off and restart it it acts normally, it won't rev up anymore until the truck sits a while, It beats me.
strokin'_tatsch
Texas Chapter
27
Apr 28, 2011 04:29 PM
Toyman
Michigan Chapter
17
Jun 14, 2008 01:34 PM
laynrubber
Aug 6, 2006 11:41 PM
mustange70
Canadian National Chapter
13
May 19, 2006 01:21 PM
gtex
Texas Chapter
Sep 22, 2004 02:54 PM
