flathead v-8 engine swap
Old Nov 30, 2005 | 03:21 PM
olered53's Avatar
olered53
Question flathead v-8 engine swap
what do i have to do to put a 1950 model flat head truck motor in my 1946 ford truck,it has flat head v-8 also,both are 1/2 ton.
Old Nov 30, 2005 | 08:00 PM
mtflat's Avatar
mtflat
Swap it in. I pulled a 51 merc V8 out of a '46 1.5 ton. As I recall - use the waterpumps on the 50 and you'll find issues with the water pipes: the 50 used smaller diameter hoses on top than the 59 series. Oil filter may have a few differences - your gauge might be actual pressure while the 50 uses an electrical sender. That's about all. Everything else is a match.
classicrat52
May 8, 2015 07:30 AM
Pappys53
Apr 25, 2014 04:16 PM
Brettzky
Flathead V8 & Flathead 6
Oct 27, 2013 10:11 AM
52panel
Apr 16, 2002 06:32 PM
