Looking for 37 1 1/2 ton upgrades
Old Nov 23, 2005 | 10:33 AM
Mike G's Avatar
Mike G
Hey gang!
I would like some input from the folks here on what updates were made in the process of restoring/rebuilding their 1.5 tons. We managed to grab my Great-Grandfather's truck off the farm and now dad has a project (since my 65 is still in pieces, I'm busy). Is there anyone that swapped over the body to something newer? We want to keep the big truck feel and will go with a nice stake bed.
Thanks all, --Mike
Old Nov 25, 2005 | 10:42 AM
GB SISSON's Avatar
GB SISSON
1 1/2 ton upgrades
Hi, I am just finishing up a 40 1 1/2 ton. I installed a 302 and a T-18 4 sp.It also has power brakes (just the master cyl and booster) from a 77 E 350 van.I used the pendullum mounted pedals from the 70 engine donor truck. I still need to rebuild the steering as it is prone to wander.So far it has been very sucessful.These trucks have a great frame,large brakes,which I totally rebuilt and from my long experience with them, steer and handle well.....okay, not like my 02 F 350 !The 40 looks completely stock if you dont look under the hood. The engine was a very nice fit, as was the trans.Shifter came thru the floor in almost the exact same spot....Good luck, GB
Old Nov 28, 2005 | 07:36 PM
46fordtruck's Avatar
46fordtruck
Your '37 has mechanical brakes, so that really should be one of the first upgrades you make after deciding on the power plant, and how you will use the truck. In high school our auto shop teacher bough a '38 1.5 ton stake in for use to work on. It was a pretty nice truck #3 condition. We replaced the mechanical brakes with ones from a '42 1.5 ton. Pretty easy to do, we just swapped the parts to the stock I-beam along with new king pins. Of course, you will still have to add the hydraulic brakes to the rear. I'd say keep the stock frame if is in good shape. It can really turn to a big nightmare doing frame swaps. So many projects are abandoned when something like a frame swap gets to be too much trouble.
BTW, that same '38 1.5 ton now has an independant front end, a BBC, and wide Mickey Thompson tires on the rear.
Old Nov 28, 2005 | 07:49 PM
46fordtruck
BTW, there is a seller on eBay sellling off the brakes and spindles from a '46-'47 big truck. Those would be the parts needed to add hydraulic brakes to your truck
Mike Mc
Nov 23, 2005 05:49 PM
mgraveman
May 30, 2004 01:21 PM
Vanhecht
32
Jan 24, 2004 03:27 PM
Crowbar65
Feb 9, 2003 08:26 AM
Mikedunn
1947 and Older Ford Trucks
Jan 26, 2002 12:01 AM
