Trip Computer Temp
Old Aug 29, 2005 | 10:57 PM
Hummer1823's Avatar
Hummer1823
Question Trip Computer Temp
Hello All... New to the Site... But been a long time reader and LOVE IT!!!
Anyway
I have a 00 PSD with the over head trip computer... And the Outside temp reading is STUCK to -40 degrees!?!?! (NO its not that cold YET in ILL) I have talked to the dealer and he said change the sensor in front behind the grill... 21.99 Later and no luck
So I am open for Suggestions... Resetting does not help (by hold down the 2 buttons for so many sec) that just allows you to ajust the compass.
Old Aug 30, 2005 | 02:17 AM
BobbyDiesel71's Avatar
BobbyDiesel71
where are you in IL?
have you joined the IL chapter yet?
we are going to have a meeting in September, you are welcome to attend
some of us live in the Chicagoland area
Old Aug 30, 2005 | 06:20 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Anyway
...Welcome to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 30, 2005 | 10:37 AM
Hummer1823's Avatar
Hummer1823
Smile
I am just west of Rockford... So close to Chicago
I have not joined the IL chapter!
Would love info about the meeting and joining!
Old Aug 30, 2005 | 11:04 AM
cookie88's Avatar
cookie88
FTE Emeritus
The wire between the temp probe and the O/H console is light blue with orange trace if you want to try to check it. Assuming the other functions are still working the whole module probably isn't bad, you might try dropping the module and looking for a broken wire, connector, resistor, etc. along that circuit.
Old Aug 30, 2005 | 11:39 AM
Hummer1823's Avatar
Hummer1823
Hey thanks cookie I will give that a try and post what i find out.
Old Aug 30, 2005 | 11:46 AM
cookie88's Avatar
cookie88
FTE Emeritus
No problem at all. There have been a few of us that have had the display go dark...there are a few tiny little resistors on the back side of the module that come loose and have to be soldered back on. Possibly something similar happening with yours.
