can't find reverse on '15
I can get 1st gear with the floor lever forward and the left pedal pressed, and 2nd gear by letting up on the pedal.
I get neutral with the floor lever in the center position and the parking brake with it pulled back.
I get no reverse at all, even with the center pedal pressed and the lever in the forward position.
Am I shifting this thing wrong or does it sound like something more serious, like a broken transmission band?
Take the top off the trans cover located under the floor board and do a visual to see it there is any loose cotton, or other fabric inside. You can access this by removing the floor board, and there is a plate held on with 4 screws. Remove these and put them far enough away from the opening that they don't accidently fall in. If they do then you will have to remove the engine to retrieve them.
Take a visit to this site as these guys are only into the Model Ts, they have helped me out a great deal, with mine.
I am not trying to take anyone away from this site, just that there is more info at the one I am directing you to.
http://www.mtfca.com/discus/messages...tml?1122420657
