What can I use to refill my transfer case fluid
Old Jul 25, 2005 | 03:25 PM
2001expy's Avatar
2001expy
I want to drain and fill the transfer case on my '01 expedition, 5.4l EB. Draining is no problem, but what I can use to refill it??
I need some sort of squeeze bottle............What do you recommend??
Thanks!
Old Jul 25, 2005 | 03:30 PM
ford390gashog's Avatar
ford390gashog
buy a hand pump with a hose at a local parts store or at walmart. its about 10.00. the transfer case takes mercon fluid.
Old Jul 25, 2005 | 05:25 PM
NoMo's Avatar
NoMo
Be sure to remove the FILL plug BEFORE you drain the transfer case. Been more than one person drain the case then realize they couldn't get the fill plug out!
I've tried various fill methods and now use the hand pump w/hose (mentioned above) that screws into the fluid bottle. Works great!
Old Jul 25, 2005 | 05:54 PM
2001expy's Avatar
2001expy
I will check WalMart for the hand pump. I don't remember seeing one, but I've never looked! Do you know who makes it?
Thanks for the advice on the fill plug. With my luck, I'd be one of those with a frozen plug. Didn't even cross my mind, thanks!
Old Jul 25, 2005 | 05:56 PM
ford390gashog
i think it was made by blitz the best ones are the ones that screw on the bottle and you pump it.
Old Jul 25, 2005 | 07:26 PM
Luzer27's Avatar
Luzer27
Some help. Go to the marine section of Walmart in sporting goods or parts store or boat shop. They make a pump that screws onto quart bottles for about 7 bucks. Even fancier is a drill pump that goes on cordless drill also a boat store item.
Dave
Old Sep 11, 2005 | 05:19 PM
NewExpeditionOwner's Avatar
NewExpeditionOwner
How many quarts does the 99 Expedy hold???? Any it takes mercon fluid right? thanks!
Rick
Old Sep 11, 2005 | 05:37 PM
holiday187's Avatar
holiday187
it takes 2 quarts. I used b&m trick shift performance transmission fluid. workks great.
Old Sep 11, 2005 | 06:17 PM
NewExpeditionOwner
ok...thanks!!!!!
Old Sep 12, 2005 | 06:28 PM
NewExpeditionOwner
Thumbs up
Man....once again I've saved money from reading this forum.....I paid $4. for the 2 qts. of tranny fluid and got it done in only a few minutes....The Valvoline Quick change place wanted $50 to do it!!!! AND the big win is that it took care of my shudder on take off!!! The oil was pretty dark too!!!! thanks again, everyone!!
Rick
