Air pump removal question...
Old Jul 16, 2005 | 12:36 PM
ddrumman2004's Avatar
ddrumman2004
Hi folks. I have an 86 F-150 4x4 with a 302 that I use strictly for work. That means hauling stuff around the "farm" so to speak. Can I remove the air pump(smog) from the endine without ant problems? Will the fuel injection computer still function ok?
I would really like to remove it if I can and plug or cap off all associated lines invloved.
Can I do this and still expect the engine to run ok?
The truck has 203K miles on it.
Richard
Old Jul 17, 2005 | 11:49 AM
LxMan1's Avatar
LxMan1
Yes, it will run ok. Why do you want to remove it? Is it bad?
Old Jul 17, 2005 | 06:09 PM
ddrumman2004
I don't think it's bad......but it is in the way of changing the front plug on the passenger side of the truck.
Thanks for the reply sir!
Old Jul 18, 2005 | 12:51 AM
LxMan1's Avatar
LxMan1
No problem. You can remove it if you want to. It may throw a check engine light if you unhook the tubing and wiring from the valves, but it won't hurt anything.
