What the cylinder order for the 46 g-series flathead 6?
with the distributor mounted in the front) - is cylinder number one towards the front of the engine?
15 is to young to date, 36 is to old, and 24 just right.
I'm sure one of the more knowledgeable guys will be here to answer your question with more certainty
Model Designation: Six Cylinder - 6GA
Wheel base: 114
Valve Location: In block
Bore and Stroke: 3.3" x 4.4"
Piston displacement, Cubic Inches: 226.0
Compression ratio: 6.70
Maximum Brake Horsepower: 90 @ 3300 RPM
Maximum Torque Lbs.Ft. @ RPM: 180 @ 1200
Normal Oil Pressure Pounds: 30
TUNE UP SPECIFICATIONS
Spark Plug Make: Champion H10
Spark Plug Gap, Inch: .030
Firing Order: 153624
Ignition Timing: No timing mark. (Spark is advanced or retarded by adjusting vacuum brake set screw on distributor housing)
Engine Idle Speed, RPM: Manual shift trans. 475; automatic shift trans. N/A
Cylinder Head Torque Lbs.Ft.: 50-60
Compression Pressure & Cranking Speed: 110 Min.
PISTON AND RING SPECIFICATIONS
Fitting Pistons with Scale:
Removed from Above
Shim thickness to use:
With sleeves and aluminum pistons .0025";
without sleeves .002"
Pounds Pull on Scale: 6 to 12
Rings: (for tapered bores for minimum clearance fit rings in tightest portion of ring travel)
Ring Gap, Minimum: Compression: .010
Ring Gap, Minimum: Oil: .010
Clearance in Groove: Compression: .0015-.003
Clearance in Groove: Oil: .0015-.003
Wristpin Diameter, Inch: .850
VALVE SPECIFICATIONS
Operating Clearance:
Intake: .014 Cold
Exhaust: .014 Cold
Clearance for Timing Intake: .014
Valve Seat Angle, degrees: 45
Valve Timing: (BTDC = before top dead center; ATDC = after top dead center)
Intake opens: 5 BTDC
Exhaust Closes Degrees ATDC: 4
Valve Spring Pressure Pounds at Inches Length:
Spring: 37 @ 2-1/8
Valve Stem Clearance:
Intake: .0015-0035
Exhaust: .0015-.0035
ENGINE BEARING SPECIFICATIONS
Connecting Rod Bearings:
Journal Diameter, Inches: 2.2350
Bearing Clearance, Inch: .0017-.003
Rod End Play, Inch: .003-.007
Rod Bolt Tension, Lbs.Ft.: 40
Main Bearings:
Journal Diameter, Inches: 2.4990
Bearing Clearance, Inch: .000-.003
Crankshaft End Play, Inch (taken on rear bearing): .002-.006
Main Bolt Tension, Lbs.Ft.: 80
CAPACITY DATA
Cooling System:
Without heater: 14-1/2 quarts
With heater: 15-1/2 quarts
Fuel Tank: 17 gallons
Engine Oil: 5 quarts
Transmission: 2-3/4 pints
Rear Axle: 2-1/2 pints
VACUUM BRAKE DISTRIBUTOR SPECIFICATIONS
Distributor part number: 5GA-12127
Cam Angle, degrees: 36
Breaker Gap, Inch: .014-.016
Condenser Capacity: .21-.25 Mfds.
Breaker Arm Spring Tension: 20-24 Oz.
Centrifugal Advance:
Advance starts 1/2 degrees before top center
Full Advance: 9 degrees @ 1250 RPM
GENERATOR SPECIFICATIONS
Generator Number: 21A-10000 (generator rotates clockwise)
Generator output: 30 Amps @ 1700 RPM
Brush Spring Tension: 30 oz.
REGULATOR SPECIFICATIONS
Regulator Number: 8A-10505
Cutout Relay:
Voltage to close points: 6.3
Reverse Current to Open Points: 0-8 amps
Armature Air Gap: .017
Voltage Regulator Setting: 7.3 volts
Current Regulator Setting: 30 amps
Current and voltage armature air gap, Inch: .035
Hope this helps
Rod
