54 F-100 Coil Wire
Old Jul 5, 2005 | 10:02 PM
pm5471's Avatar
pm5471
54 F-100 Coil Wire
The body is off the frame and i want to start the engine. Rebuilt 6 cyl original engine and 6volt pos. ground as original. I have the frame finished and engine installed complete rebuild on the frame. Which post on the battery should i connect the wire temperaly just to start it
pete
Old Jul 5, 2005 | 10:39 PM
Earl's Avatar
Earl
Connect the ignition feed wire to the negative battery post if it's a positive ground system as you mentioned.
I knew I'd have my engine done for a long time before I was ready to install the cab, so I got a $7 universal ignition switch from Auto Zone and mounted it in one of the holes in the frame. I got a new starter solenoid too since I was going to need it anyway. A few small wires for the ignition circuit, some new battery cables I was going to need anyway, and I have a sound, working start/ignition switch. Might be something to consider if you will be a while getting your cab finished. There are some pictures at the Earl's World link in my signature block below.
Old Jul 5, 2005 | 10:40 PM
hiball3985's Avatar
hiball3985
I think it would be from -side of coil to - battery on a positive ground system
Old Jul 5, 2005 | 10:42 PM
hiball3985's Avatar
hiball3985
EARL..you type faster than me.........lol
crs22
20
Aug 8, 2014 12:32 PM
C G B
31
May 23, 2011 09:27 PM
b_mckendry
Bronco II
Aug 24, 2010 12:59 PM
Twelve
Sep 13, 2009 08:00 PM
Shorty 66
13
Apr 24, 2006 09:02 AM
