Overheating in 4th July parade
Old Jul 4, 2005 | 06:02 PM
rabbitearscarver's Avatar
rabbitearscarver
My '64 f-100 has a '70 390 in it. Occasionally, I run it in a parade, where you're going super slow (granny gear) and stopping, and of course I run very hot. Today, I overheated and had to pull out of the parade, steam pouring out from the hood!
Juuuust a little embarassing.
So, what can I do? Bigger fan? Auxiliary fan? Help!!
Thanks in advance. -Dave
Old Jul 4, 2005 | 06:58 PM
RR4E's Avatar
RR4E
Are you running a big enough radiator to support that engine?
I'm guessing you dropped in the 390 in place of a former 352, or simply changed engine mounts and bellhousing to get it in there.
I had one in my '69 4x4 that sufferred from heat issues during rock crawling or other low speed situations. Installing a 7 blade clutch fan, fan shroud, and a 4 core rad from a 460 cured that issue right up. You may also want to add an over-flow tank.
Old Jul 4, 2005 | 07:23 PM
barry's Avatar
barry
HOw old is the radiator? It could be partially clogged at the lower core tubes. I'd definitely put a 7 blade fan on as reccommended above. On thing to try is to get the truck up to operating temp and while it is running , feel the front side of the radiator for any cool or cold spots. That means clogs. It should be fairly uniform all over. Parades are tough on older vehicles. Not enough air moving thru the radiator. They heat up fast.
Barry
Old Jul 5, 2005 | 05:13 AM
ddavidv's Avatar
ddavidv
A 64 had a Y block if not a 6, so the radiator I am fairly certain is much smaller than the ones used in the FE trucks. I think you need to increase cooling capacity first. With the factory stuff in my 65, my FE does not overheat, though there certainly is room for improvement via bigger radiator, fan with more blades, shrouds, etc but I don't believe in changing things if there isn't a problem. My radiator is NEW also, which probably helps as noted above.
Old Jul 5, 2005 | 06:27 AM
jowilker's Avatar
jowilker
rabbit, Welcome to FTE, The best truck show on the net.
The problem is the design of the truck. I have a FE in my 66. I have the proper size radiator, of resent vintage. The truck will run fine as long as it is moving and getting getting air flow. I know mine would do the same as yours, should I have done what you did. I have a 97 Taurus that I sat for in 97º heat for 1 1/2 hours ideling with the ac on. The temp guage never moved one bit. Thing is, you can't see the radiator at all, but the electric fans pull all the air through there that it needs.
Our trucks didn't come with a shroud, and there is a lot ways for air to move in many different directions, not focused like the Taurus. If you will look at the trucks as newer models came out you will find flat pieces of rubber along the top of the grill to the core support directing the air better. Then cross flow radiators were introduced.
Basically there is nothing wrong with your truck, it just isn't designed to do what you were doing with it. IMHO
John
Old Jul 5, 2005 | 12:11 PM
FordBoypete's Avatar
FordBoypete
I agree with John! Welcome to FTE.
you could adapt a fan shroud to control air flow across the core and go up to a 5 blade, which would resolve a lot of the Low Speed X Hi Temp problem you describe.
For my $.02, i think a shroud & commercial fan set up is better than an electric add on.
It's cheaper than the Aluminum Cross flow I bought from Modine for another Ford Truck I have. . . . but the 4 row aluminum cross flow lets me run a +198 T-Stat & keep my EFI happy, and still cools my coolant at idle. . . .
FBp
Old Jul 5, 2005 | 12:29 PM
bertha66's Avatar
bertha66
Ran my 66 4x4 in the parade also, it has a 390 GT engine with a new Radiator, I run a 5 blade nonclutch fan in it, it got good and warm. Ran the RPM's up once in awhile to keep the air flow going. Once out of the parade route took it out to the hi-way for a little cool down. I run a 180 t-stat in it and it seems to be happy with that.
Old Jul 5, 2005 | 04:03 PM
rogerf100's Avatar
rogerf100
I think jowilker is on the right track. If you run a thermostatic controlled electric fan with enough CFM you will not overheat the engine, provided the radiator is in good condition and has enough capacity for the 390. The low parade speed combined with the slow fan speed can not cool the radiator in summer heat, not enough air flow and low volume of coolant flow at idle.
You can setup the electric fan as either a pusher or a puller.
Old Jul 5, 2005 | 11:52 PM
Daddywags's Avatar
Daddywags
There's a reason so many rodders run an electric fan on their modified cars. I had the same problem on my '54 Chevy when I V-8ed it with a new radiator. A "puller" electric fan solved the overheating problem the first time it switched on. If you don't have enough room between your radiator/engine, you can use a pusher mounted in front of the radiator. I've seen cars that don't even use an engine fan at all, but not sure I'd go that route myself.
Old Jul 6, 2005 | 04:44 AM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
I ran a 351w built and it wanted to run hot while riding slow speeds, so I did
install a bigger Rad, but it still seemed a little on the high side, so I tried this
product called (kool-aid) it droped the temp 20 degrees, it really did work
real good and it lubes your water pump also! Some people I have told about
it though the years always used to say " I don't use Snake oil ".
P.S I'm sure about how much it dropped the temp, because I was running a
good Auto meter gauge! The can said that the temp drop may vary.
Welcome to (FTE)!
Old Jul 10, 2005 | 12:06 AM
rabbitearscarver
Thanks guys for all the input. I looked into electric fans, and I don't have much room on the outside for it. Are you suggesting I unhook the existing engine fan and put the electric one there? Dumb Question??
Thanks
Old Jul 10, 2005 | 05:56 AM
jowilker's Avatar
jowilker
Thanks
Yes, Should you choose that route, you remove the mechanical fan back to the pully when the electric is installed.
John
Old Jul 10, 2005 | 10:35 AM
jd_sylvia's Avatar
jd_sylvia
After getting my 65 up and running after the wreck I noticed that while idleing in the California heat and traffic it would warm up. Found a fan shroud on a 65 at Pick-N-Pull and what an amazing differance. The ford part number is C8TA 8146 S, It fits perfect I don't know if you can still get it from Ford or not.
Good luck and keep her cool.
jd
Old Jul 14, 2005 | 08:18 AM
55cub's Avatar
55cub
I'm in the same boat with my '65. Just need better air flow at idle. I have a rebuilt rad. and new fan shroud.
Still has the 4 blade fan.
Should I just upgrade to a five blade (do you get these from an yard out of a old galixy or something??) or should I go with an electric pluller??
Do the electric work as well? And do they really save power?
GB
Old Jul 15, 2005 | 06:32 AM
jowilker's Avatar
jowilker
GB
Cub, The shroud is most important in your list, because it directs air flow. The flex fan blade will pull more air, and you may need to use shorter spacer behind the blade.
The power loss thing is only related to racing, doubt you would ever see any difference on the street. IMHO
John
