04 Explorer With FF Flexible Fuel Compatible???
Old 06-20-2005, 09:24 PM
stacyj's Avatar
stacyj
stacyj is offline
The 04 Explorer i bought is Capable of using Flexible Fuel (I only use regular unleaded, we don't have the ethonal mix around here). The question i have is are the computers de-tuned just incase you use something other than regular unleaded? I have a sticker under that says something about the computer. I can get the code from the sticker if that helps...
Thanks...
Old 06-21-2005, 12:42 PM
87 XLT's Avatar
87 XLT
87 XLT is offline
Theres a sensor in the fuel line that tells the computer which fuel you are using. The computer adjusts accordingly.
Does your owners manual say anything about this?
Old 06-21-2005, 01:08 PM
stacyj's Avatar
stacyj
stacyj is offline
Not really. It has very little info on the subject. There is a sticker under the hood that says the PCM has been modified. It also has a # on the sticker if that helps.
Thanks
Old 06-21-2005, 01:29 PM
87 XLT's Avatar
87 XLT
87 XLT is offline
Might have been a "technical service bulletin" for the original PCM & the dealer has swapped it.
Click on "recalls & technical service bulletins" at www.alldata.com, then enter the info for your truck & see what you come up with.
If all else fails, check with the dealer.
Old 06-21-2005, 04:35 PM
stacyj's Avatar
stacyj
stacyj is offline
Here is the text on the sticker.
PCM Calibration
4U7A-12A650 ATA
CHANGE AUTHORITY FPS8262 9/78
