setting timing on 94 f150 4.9L
Old Apr 29, 2005 | 09:39 AM
97rangerguy's Avatar
97rangerguy
how do i go about setting the timing on a 4.9L 300 cu 94 f150
i know little about timing setting ... is there a button, clip, plug u have to remove off the wiring any to set timing or just loosen bolt on distributor and set timming .??
Old Apr 29, 2005 | 10:47 PM
subnet76's Avatar
subnet76
There is a bolt you losen up just a little on the distributor and then, I believe turn it left to advance and Right to retard. Use a timming light if you have one. If not you can listen to the motor when lifters start tapping back of just a little till it goes away. < just incase you dont know>.
ws23l77187904
16
Jan 28, 2015 12:35 PM
Maiden23
Aftermarket Products
Sep 10, 2014 09:49 AM
JSTJ704
Jul 1, 2014 05:55 PM
94E1504.9L
Jan 3, 2009 07:48 PM
MikeinBurien
Aug 10, 2006 09:07 PM
