RABS diagnostic Connector Location
Old Apr 11, 2005 | 09:17 PM
pic498's Avatar
pic498
everytime i take off in my 95 Ranger, the Yellow ABS light kicks on and then the red parking brake light flashes a few times... I realized this was a fault that was being stored, and began the treacherous hunt for the RABS test connector as Haynes calls it... from the pictures i saw in the manual, it's a connector that is attached to the front of the under-hood fuse panel with an orange/black wire. There are two connectors on the fuse panel, however none of them have an orange/black wire... and none of them give me the flash code... can anyone help me as to the reason this light is on and where the location of the connector is... thanks
Old Apr 11, 2005 | 11:00 PM
AlfredB1979's Avatar
AlfredB1979
The Haynes tells me that the test connector for Rear ABS systems is a Red and Black/Orange wiring combo. That is for the ABS test connector.
Red light = low fluid level.
Yellow light = ABS system fault and your brakes will lock up when it comes to that kind of situation.
All you can do is check your hoses, fluid level, any and all wiring to the connectors in the system wiring harness.
You can not pull ABS codes yourself if you were wondering.
Old Apr 12, 2005 | 08:23 PM
Ken00's Avatar
Ken00
Just to make it clear, you can pull the codes from a RABS system, 4 wheel ABS system requires an ODB-II scan tool.
Old Apr 12, 2005 | 09:09 PM
pic498's Avatar
pic498
yeah, i thought you could... RABS here... however albert was right--it was the brake fluid... i tend to miss the simple things alot of times...
Old Apr 13, 2005 | 07:25 PM
Ken00's Avatar
Ken00
Glad to hear you found the problem and it was easy.
Old Apr 14, 2005 | 08:33 AM
pawpaw's Avatar
pawpaw
Well now that the system has your attention, LOL, you need to find out WHY the brake fluid level was low, as the brake system is a closed one & fluid isn't normally consumed.
Level can drop from wear to the pads or shoes or from a leak in the system, so both causes need to be checked out.
All that said, has the brake fluid been changed lately, say in the last 2-3 years????
If not, it's past due for a flush.
Fresh brakefluid is sort of a pet peve of pawpaw's, as it's one of those "forgotten" fluids!!!!
I do mine every two years with MotorCraft fluid, it's good stuff & your system will love you for it!!!!
Staceman
Aerostar
20
May 30, 2020 12:29 PM
SteveL53
1997 - 2003 F150
Sep 18, 2014 06:20 AM
GreenTerracePSD
Aug 7, 2014 09:13 PM
94GreenTruck
Jul 25, 2014 12:22 PM
Rob88
16
Jul 11, 2001 12:30 AM
