Clutch pedal to rod lever---can you get new ?
Old Apr 2, 2005 | 09:39 PM
F150Lariat79's Avatar
F150Lariat79
Howdy,
Does anyone know if you can get new the small lever that connects
clutch pedal to linkage rod ? Know that it could be fixed with
weld & redrill, but would like to find a new one if possible. Can't get
them from dealer or mail order places I know of. Thanks much. JR
Old Apr 2, 2005 | 11:00 PM
Torque1st's Avatar
Torque1st
Posting Legend
Slavage yard only.
Old Apr 3, 2005 | 09:34 PM
DeathMobile's Avatar
DeathMobile
Heim Joint it!
Mine was worn to the point that it was sticking, so recognizing that the stock set-up was really too simple and for a few more dollars, I decided to get some heim joints, rod, and fabbed one up. I bought joints with grease fittings as well. This set-up works great, doesn't require welding and re-drilling, and I did the same for the adjustment rod, so eventhought the equalizer bar is worn, the way that the heims (with studs) mount, it is a moot point.
Old Apr 4, 2005 | 09:36 AM
73Custom's Avatar
73Custom
That's a good idea. I've been trying to come up with a better setup than factory. Where did you get your joints? Did you use threaded rod between the joints or pipe or what? Pics would be great if you have some...
Marty
Old Apr 8, 2005 | 08:39 PM
Scot's Avatar
Scot
I threaded the original rod and used heim joints. I bought them from a bearing supply.
